Mine does exactly the same thing. I've seen another R32 RB20DET that also does the same thing.
If you drive it with that flat spot it tends to bring boost up really easy when cruising on light throttle, lots of smoke (black/grey) will be seen in the rear-vision mirror if you give it a little squirt in first or second.
Mine has done it for the last 60,000km's. Nothing to worry about, just warm it up for 3-5mins before driving it. It will also hit boost cut ALOT easier when cold.
When cold and idling if I attempt to raise the rev's slight by pressing the accelerator really lightly the rev's will die and cause the car to start running rough until I either press the accelerator slightly more or take my foot off.
I've also tried everything, there is a possibility of injectors?!?
There is no direct way the R32 ECU can reduce boost when cold as the RB20DET uses the standard plum from infront of the turbo to the wastegate with no solanoids inbetween. The only way be it intended or not is to bring the boost cut in a little earlier. I'm running upwards of 1bar of boost on the stock ecu so i'd say that is my problem.
Mates thanks for the feedback,looks like its reasonably common, although its frustrating when youre trying everything though and nothing seems to improve it,the thing goes like a scalded cat when warm, so it seems he will just have to warm it up first ,just like the first rotaries.
My car does the same thing. If you drive it off gently when cold you get to about 3k RPM and are trying to just go a bit faster it seems to really die in the arse. If you put your foot down a bit or let it struggle there for a few seconds it'll get through the dead spot and come good again. It really doesn't feel nice to drive when cold though! I usually try and short shift just before 3k - it has another not-perfect spot around 2.5k but the warmup period is only about 3-4 mins so i'll deal with it if it's a common fault with the ECU's tuning and not something that can be simply fixed. Contemplated cleaning the AFM but had my doubts it would make a difference.
When warm, I can sometimes feel the same dead spot but it is far reduced. Most of the time I only notice it when it's cold.
I also notice a slight dead spot in the accelerator when warm and idling around in first on and off the accelerator (looking for a car park in shopping centres) Hardly noticible, its so so damn small.
My old VL 5 speed NA 3ltr had it pretty bad, normal street driving you wouldn't notice it, in car parks looking for a park it was a real pain in the arse.
Come to think of it so did my VS V8 5speed. But not when cold.
Has anyone thought of the O2 sensor having problems with its preheat?
I threw my car in diag mode with the o2 sensor flashing on the dash.
As the rich lean rich lean started to flash the flat spot went away.
Also.. Nothing related as the flat spots always been there BUT i've started to loose approx 70km's to a tank of juice. :) I am barely scraping in on 400km's to a tank since the last 15,000km's. Previously I would hit 470km's to a tank then if I did a little bit of 100km/h cruising I could easily break the 500km to a tank.
If it only happens when the car is cold, its probably the ecu trying to stop the turbos making boost whilst the oil is still cold. My car does it, until the oil pressure gauge starts falling the car makes no boost at all, which is a good thing and i dont know why anyone would want to change it.
Today we tried an aftermarket computer on it off our mates car and it was driveable straight away , no flat spot ,he never gives his car stick when cold,but it shows that MR. NISSAN didnt want the car driven till warm,so its back on with the standard one and wait 3 MINS,thanks for the feedback.
contray to previous posts, i HAD a serious flat spot when cold in my car also...
did an ECU diagnostics test and it came up with the code for knock sensor. so i had a look at the knock sensors and one of them was unplugged! so i put it back in, and presto - no more flat spot! worth a try as it only takes 5 sec to see if the plug is in
(note: plugs located just below intake manifold. one is in between runners 1-2 and otehr 4-5. they are green plugs with a white clip that has to go into it)
good luck guys,
Warren.
When cruising and the flat spot is apparent I can hear the turbo spooling & the boost guage is definately reading 1psi or so. It doesn't stop the car making boost. If anything it for some reason makes the car make boost easier and earlier. It feels like the car is sputtering without the missing the car starts to make boost then all of a sudden it comes out of the flat spot and off you go with a bit of fuel smoke behind you.
Upon cruising say 60km/h you watch the boost guage when you feel the flat spot and it will be making boost not vacuum as it should when cruising.
I remember when the car didn't used to do it.. If anything the car used to feel punchier when cold.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
