I was thinking just that when I had to squash the section of the hose going into the engine bay. I didn't have to by much and don't think it will significantly hamper airflow enough for a significant difference. The diameter hose you're using looks to be much bigger than mine.
I haven't measured mine properly yet, but a hose slightly smaller than mine would suit best if you can get your hands on one I think. If it wasn't for that little protruding bracket looking piece of metal right under the hole inside the guard it would be a perfect fit!
I'd say having a hose fitted is better than nothing at all - At least you're channeling it to the Airbox.
This was one of the first mods I did to My GTR.
I think it is blocked to satisfy the sound levels and performance restrictions in Japan. It is anothe case of Nissan looking after GTR owners where you can open it to improve performance and if you are pinged for noise then just put it back in.
I have subsequently gone to Apexi pods with an enclosed carbon fibre air box. This same opening in the panel provides cold air now to the air box.
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
