Hey guys,
I was wondering if people could help me out and explain what the cam specifics (degrees/lift) mean and how they affect the car?
Currently running a gt35r with a rb26/30 head. Most people advise 260s with 9.15lift as they are the maximum you can get without modifying the head. ive had a look around and found some of the following pon cams
Duration: IN 260, EX 260 Lift: IN,EX 9.15mm
Duration IN 260, EX 252, Lift: IN,EX 9.15mm
Can someone explain to me what the degrees affects by lowering or increasing it? and what happens when you have a higher or lower inlet or exhaust lift? What are the consequences when doing either or?
Thanks guys
Edited by Jap_Muscle
ks for that ash. was a good read. I guess my questions now are.
how does having a bigger IN duration compared to a bigger EX duration affect things?
how does one determine what cams to choose based on an ideal rev range? eg if I want the action to be around 4-6000rpm, what do I look at?
i prefer to use larger exhaust cams on sr's @ around 300rwkw 264 inl 272 exh.
on the rb's its all about the capacity, 3l will take a big cam without any loss whereas a 20 withe the same cam will be a dog.
On your 26/30 i would go 260 in and exhaust.
look up the t67 on stagea thread a few posts down, i just did a back to back on a rb25 with cams and t67 dyno results are there.
it seems everyone does agree with you trent. 260s are the way to go i guess.
as i mentioned before my redline is currently at 7000. what can i do to increase it safely? do i need a new crank? would it be worth it even as i hear shifting to the next gear would give me more power anyway? it seems the rb30s run a bit out of puff in the high revrange.
RIPS rb30s consistantly rev to 9500rpm all day though =[
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
