Hello Guys,
Dont really come online much, just a few questions.
Long story short for anyone interested.
Currently running a rb26 in my 180sx and at the start of the year planned to get more power so i had all the bolt on mods already and tuned.
Running std internals i opted for a rebuild to go forged, took it to a workshop in Sydney and had the work carried out. Top brand internals were used and invoice cost over 10k, basically dropped the car of there and returned with all work done.
A few days later i notice smoke out the exhaust and motor wasnt running properly. So i took it back the same day, left it over at the workshop to sort out. The response was compression down on 4 cylinders, anyway they're not willing to sort out the problem
and im just exhausted now. Time to move on and found out that the motor was a rush job with poor quality and workshop not willing to accept any responisibility. 10k down the girgular oh well, expensive past time.
Want to know of reputable workshops which provide warranty for built motors, honest workshops who will provide warranty. I'll phone around and get quotes and see what is the best value for money. Also prices you've paid for built motors just to know the ball
park figure to accept.
Thanks Guys
Edited by DR 180
https://www.sau.com.au/forums/topic/328384-engine-build-warranty/
Welcome to SAU :blink:
We wish it were under better circumstances.
What's your 1st name?
And more to the point, before we get into the guts of things (and let you know where you can take your car), where are you situated? :P
$10K of work?
Was it itemised? To salvage some of the money already spent, (and before possibly going to court or small-claims), you'll need to set up a diary/journal. Journalise verbatim, your conversations and who was present (to witness). Any members of a tribunal regard a diary & documentation much more highly than a verbal.
Might you then require an engineer to pull your engine down and document if the itemised work done was second-rate, or he (the mechanic) used old, tired parts? If so, diarise that!
Thanks for the welcome :thumbsup:
Im from Sydney, Castle hill, workshop was down the road from me.
I've spent 3 months trying to fight it, but it seems im getting nowhere.
Just totally exhausted mentally to even waste another attempt with the workshop, there completely ruthless.The stock rb26 was running the same setup perfectly fine for close to 2 years, 14,000 kms. Yes the invoice was itemised for parts and labour.
Just shopping around now for a reputable place for a rebuild now. Main things i need a warranty and experience, compare prices and see. Not willing to keep the car of the road any longer, hopefully in a few months time. Last thing i want is another poor build.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
