hey guys just wondering i was thinking of using 6 S15 480cc injectors but not sure where there power limit will be can anyone shed some light for me i dont know much about injector calculating, and i have been told running massive injectors is bad for fuel comsuption etc
Power looking at 250+ hoping for 280 not sure what it will make just dont want to run out of fuel :thumbsup:
Thanks
https://www.sau.com.au/forums/topic/328430-injector-size-for-300kw/
You can generally get 280kw with GTR injectors (6x 444cc) without sweating (without using an FPR), so I don't see any problem getting 300kw from those 480cc injectors, there is always the option of a FPR down the track to squeeze the extra 15-20w out of those S15 injectors (but generally not recommended as the extra pressure affects the spray pattern)
I thought s15 injectors were really only 440cc, except in an s15, as they run higher rail pressures? What ecu are you using?
They're actually 450cc at standard fuel pressure, 480cc is rated at a different fuel pressure as stated on that graph, cbf finding it.
Well of course you do - it's your car. However factually what you have posted is simply not possible with just 510cc injectors. Something is up.
You are either leaving something out:
Happy dyno or higher than factory fuel pressure configuration. Which one is it?
This is usually around 85% duty (give or take) in the factory fuel pressure.
510cc = 510hp
380kw = 310rwkw (or so)... at 85% duty.
360rwkw @ 100% duty
Given as a number of people have stated 440cc injectors max out ~300-310rwkw
440cc = 440hp.
330kw or 260rwkw @ 85%
300rwkw @ 100% which is exactly the max point for standard fuel pressures as already stated (surprise!)
Disagree all you want, 510cc injectors simply cannot be flowing 400hp @ 45% duty. They can only supply 510hp @ 85%
There is more than enough information/results/posts in the pages of this forum, and all across various injector suppliers to back this up, including the 3 people that already so far disagree and no doubt there will be more if this thread keeps going.
EG: If you would make your claim with 510's @ 45% duty, that would mean not one RB26 owner would ever have needed to upgrade factory injectors for 300-320rwkw.
Fact is every single RB26 owner has had to do so... Proof is in the pudding.
(given your claim would mean 440c injectors flowing 320rwkw without being maxed out, an impossibility @ factory pressures).
It's fairly simple. Don't get the size that's just big enough for your power level, because once you are there, you'll want more. Guaranteed.
Go at least 740cc so you can run 50/50 ethanol or E85 (if it ever gets consistent out of the bowser).
If you tune it right there's no harm in running bigger injectors, very little cost difference, and way more headroom for more power down the track.
Do it once, do it right. :P
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
