Hi all. Just wanting to know if anyone recognises the make of this turbo, by it's design, or markings. Was told it was a rebuilt one with garrett parts but can neither confirm nor deny. had the housings off an the wheels are in perfect condition. No play in the shaft and spins freely.
Also what's people's thoughts. I initially bought it to put onto an rb30det, long story short I ended up putting 25det neo back in the car. But when money allows was still thinking of using this on my 25, But I sorta think this will be too big and quite laggy. The other mods that would follow with it would be front face plenum, high rise exhaust manifold, 60mm hks style waste gate, 650cc injectors, and suitable after market computer. I have all the parts except computer. Anyone hazard any ideas on how responsive/powerful this setup will be? Thanks for any help, or input.
https://www.sau.com.au/forums/topic/328452-turbo-identification/
Yeah looks pretty big! Hard to tell from the pics how big it is cos there's nothing to scale it to. I'm gonna hazard a very loose guess and say it's an apexi turbo. That compressor housing doesn't look very Garrett/hks/Mitsubishi, but does look similar to other alexi turbos I've seen. Check the turbo all over for part numbers and chuck them in to google, see what they come up with!
Do you have any specs? I.e. Exhaust flange size, exhaust wheel size, compressor wheel size etc? That should give ya an idea of how laggy/powerful it'll be.
I'd recommend nistune daughter board, soo easy! Just send off your stock ECU, give em some time and then you'll have a tunable ECU that is cheaper, more effective and allows you to retain factory driveability and all the sensors, compared to other computers.
That split pulse exhaust housing is pretty good too, should spool up a little quicker than normal.
Good luck dude!
Yeah positive. The exhaust manifold I have is t4 flange, so had it changed to t3 to suit. Anyone hazard any more guesses. The only turbo's I've found with 6bolt exhaust flange like that has been a garrett gt32, but it's a diffrent looking/size turbo altogether. Would appreciate any help, thinking of selling this and down grading size, if people think it's too large.
Its a TO4E with in .84 split pulse turbine housing with a Cropped turbine wheel. I can't see your comp wheel, but they comes out of factory with a 76mm 56T tall wheel that is rated to about 500HP.
Its very laggy even with standard turbine wheel, its going to be even laggier with the crop. I'd say it will hit 20psi around 5500RPMs with plenty of torque.
Thanks for the input. No there's no numbers, or tags on the centre cartridge. I've also added a picture of the compressor wheel. And thanks Hypergear, any idea on the make?
Looks like a 82mm comp wheel. Its a custom build turbo trying to archive 600HP. The GT3582 would be lot more responsive. Its going to be very laggy to run on a RB25det. Probably good for a 3L+ engine.
Early Garrett stuff...and yes T04E is the turbo.
Journal bearing too so laggier than normal especially in that frame size. These are approx 15year old technology.
You'd be better off with a GT3082R or 3582R
Looks like it has a Garrett GT wheel in there though rather than the old T04S 7-blade ones :blink:
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
