Yous all suck if you're getting under 400kms to a tank in a non-GTR.
I just did 463km, with 315kms of that of spirited run to Bathurst and back.
Why should a GTR be more fuel hungry?
My motors:
RB25, 270rwkw - 450-500km around town, 550-600 freeway
RB26, 280rwkw - 450-500km around town, 550-600 freeway
Identical :D
Pretty sure i have a 55L tank as well (never run it much below 1/4)
All of mine are with a nastier diff ratio as well, so I am doing high RPM @ 100km/h to you all :)
That said, if i get onto the loud pedal i can mince a tank in less than 300km's
am i the only one that doesnt check or work it out? i just go and fill up whenever i need to no matter what day it is, usually when i have about a quater of a tank left and thats it, i dont even look at the price when im filling up lol.
LOL +1.. always find vortex 98 for her and fill up once a week. its never been low so i never worry about it :)
I'm lucky if I get 350ks beween fills. And then it takes around 50Ls to fill it.
I'm wondering if a new o2 sensor will improve things, along with a Nistune and dyno time.
LOL +1.. always find vortex 98 for her and fill up once a week. its never been low so i never worry about it ;)
Once a week!!!!!
God damn. If I fill up 3 times a week it's been a cheap week.
Wish I was like that, but I'm obsessed with the trip meter haha. It can be a good way to tell if your car isn't running properly / as good as it could be. I do fill up whenever I need it though...stuff holding out for queues and cheap prices to save a couple of dollars. If you bought a Skyline for good fuel economy you did it wrong from the start I say!
Yer! Give the O2 sensor a go mate, it should be standard with every purchase of a Skyline haha! Instant 50-60km extra to a tank if it ain't been changed before.
Ummm.... ;)
BP Ultimate: 141.9c, 423.6km, 49.34 L = 11.65L/100km = $16.53/100km
BP Premium: 134.9c, 265.2km, 34.87 L = 13.15L/100km = $17.74/100km
BP Premiun: 134.9, 446.3km, 53.74L = 12.04L/100km = $16.24/100km
BP Ultimate: 140.7c, 476km, 51.12L = 10.74L/100km = $15.11/100km
Caltex Vortex: 143.9-4c = 139.9, 300km, 35.54L = 11.85L/100km = $16.57/100km
Sucks that BP Ultimate is currently the best, I want to boycott them bad. Going to move onto Mobil and Shell soon, hopefully they are awesome.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
