1998 R34 Skyline Gt-t Coupe - White With Factory Sunroof
Hi Guys,
Selling my car as listed below. (First Australian Owner.)
Model: 1998 R34 GT-T Coupe
Colour:  White (QM1)
Engine Type: RB25DET NEO
Transmission: 5sp Manual
Suspension:  HSD TT-Series Coilovers (Street Spec - 8kg Front, 6kg Rear) very comfortable on the street.
Wheels/Tyres: 18" Osaka Racing Wheels, Kumho Tyres
Mods:
• ADR approved alarm/immobiliser
• Shadow Turbo Timer
• 3" 5Zigen catback exhaust
• Downpipe
• Apexi Power Intake Pod Filter
• Splitfire Coilpacks
• NGK Iridium Spark Plugs (BKR6EIX-11)
• Alloy Radiator
• Original OEM Xenon headlights still fitted
Interior:
• Front & Rear Leatherette Seats (Black with Black Perforated centres, Red Stitching) professionally fitted by Proseat.
• Genuine leather shift boot and hand brake boot – Black with red stitching.
• Red Suede Door inserts.
• Full Blue LED dash light replacement.
• Custom car mats with Nissan logo
• Nismo GT urethane shift knob
• Factory Sunroof
Audio:
• Pioneer Avic-D3 in-dash CD/DVD player with 6.1" LCD touchscreen (This model was not available in Australia and GPS function does not work as only USA maps are available)
• Ipod connection to Avic-D3 unit fitted in glove box. Charges ipod.
• Front Speakers - Pioneer 6.5" two way aramid cone speakers
• Rear Speakers - Infinity Kappa 63.7i 6.5" three way
• JL Audio 12" Subwoofer in custom fibreglass housing with carpet
• Fusion Powerplant amplifier for Sub
Price: $24500 ONO incuding RWC and rego till March 2011
Always garaged and serviced every 6 months at Werribee Nissan.
Serious enquires only. No test pilots. NOT interested in Trades.
Contact Joseph,
Ph: 0422 836 711 ([email protected])
Thanks for looking.
  • 4 weeks later...
  • 1 month later...
  • 2 months later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
