Cheers Tim hopefully ill never need it!
Yep bracket is for mounting a trip computer - will need to build another bracket off it once I settle on a unit. May end up with a camera attached there as well.
The drivers seat bracket is set up for an aftermarket rail kit meridian have supplied. Bit worried about it actually itching to get a seat in and test with my helmet on make sure I have enough room. I am 6'2 but my girlfriend will be doing some driving as well hence the rails - she is 5'4 and struggled for height driving the car with the standard seat.
Worse comes to worst ill just loose the rails so only I can drive the car :P
ahh I've got the same challenge with my seat. the bride rails are about as low as you can get, but the cross in the cage on the roof will impact helmet room. I had to stick with only 1 diagonal on the roof for that reason
  • 4 weeks later...
Did a test fit up of the drivers seat with the mounting bracket and my helmet on.
Bad news is the mounting bracket isn't quite right - just a tad off center with the steering wheel to the window side. Meridian are going to make a few tweaks to get it sitting where I want it, and by raising the front a little will give my girlfriend a bit of extra height when the seat is slid forward.
Good news is I fit! The double diagonal cross in the roof is well out of the way my head sits up in the void perfectly. With the seat a little off center I am very close to the other bar but once the new bracket is in it will be spot on.
Old motor big end bearings from cyl 6 on left, good cyl 5 on right. Had been driving on these for a good six months... somehow they didn't spin. Chris reckons the old crank should be ok - barely any scoring on the cyl 6 journal. Thinking I might send the old crank and block off to get cleaned up and machined and have a go at putting a basic motor together for shits and giggles.
New motor is almost ready to go.
  • 3 weeks later...
Mick found this little surprise on the rear drivers quarter under the sideskirt.
Previous repair from its life back in Japan was a little shonky wasn't really sealed up properly there is rust pretty much all over it. Not worth repairing so a new quarter has been ordered from nissan.
Otherwise not much. Have ordered a new brake booster & master cyl, cluctch master cyl and a few other bits that are past it.
bummer i would have just repaired it cheaper than a qtr pnl I would think. good luck man!
Would love to have but the same panel is rusted through at the seam around the boot jamb, rear windscreen, drivers door jamb and the wheel well - this was the last straw!
There are also a few other spots that are starting to show a little but we won't be able to see the extent until it comes off.
  • 3 months later...
Awesome build man love that cage! I've got a 32GTR build on the go at the moment too but nowhere near as nice as this! I really should get off my bum and start a buildup thread but im waiting to have a new shed built soI haven't done much to it lately. Oh well these things take time. Your right though i live in Tas and there are some truly inspiring roads over here. Keep the updates coming especially the Paint Job. ;)
  • 1 month later...
Shell is up on the rotisserie now. Not the prettiest thing from underneath at the moment.
post-12551-0-18579000-1303170240_thumb.jpg post-12551-0-33256900-1303170245_thumb.jpg
Also gut stuck into cleaning the front subframe. Before shot only but needless to say it is now looking a lot nicer.
Picked up some Racepace modified Tein RA's
Midori 76mm dumps and 76mm into 90mm front pipes. Will get Racepace to sort out the rest of the exhaust.
post-12551-0-06889300-1303170907_thumb.jpg post-12551-0-27864900-1303170916_thumb.jpg post-12551-0-75263400-1303170946_thumb.jpg post-12551-0-45707000-1303170958_thumb.jpg
  • 4 weeks later...
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
