Spent yesterday on the car, mostly tidying up but got a few things done.
Removed these split HKS dumps ...
And replaced with this Midori setup. Biggest off the shelf dumps I could find, and the front pipes are pretty big compared to the JustJap ones I had on previously. Biggest in a two bolt flange.
They have really thought about the design on the Midori's, really easy to get to all the nuts as opposed to the HKS where I needed three different 12mm spanners for the nut at the back of the front dump.
Also rebuilt the clutch master with a new piston kit from Nissan. Really simple, two circlips, a good clean and check of the cylinder and back together with new bits.
Comparing pistons easy to see why it was leaking.
New piston in.
All back together and on the car.
BBQ fired up, triple level bbq burgers with the lot with an integrated egg / toasted bread centre layer and a couple of JD's - golden.
Have a spare full R34 battery cable / tray / fusebox setup so replicating the setup on the R32.
The riser into the engine bay doesn't quite work with the R32 so modified one of the brackets a bit to bolt to the same spot as the speedo cable. Will do some more work around here to make sure its locked down and doesnt interfere with anything else.
Rivnuts all the way.
Shape along the rail is identical. I lined up where the rail tapers out towards the front and the rest falls into place.
About the right amount of length up engine bay end.
Existing hole in the boot matches the standard R34 grommet.
Rear of the rail brackets fit in pretty well here too.
Up over the tailshaft. Bit different here so I may even go direct to the boot and size the cable down accordingly. No need for it to be longer than it needs to be.
How are you going to sit the positive end of the battery cable in the bay? My 33 has the battery under bonnet and I'm going to be putting in one of those cables like you are, just can't work out how I'm going to sit all the positive ends without it being dodgy or earthing out on the body.
I have the standard fuse / relay / distribution block spare from an R34 GTR so I am going to try to use that instead of the standard R32 GTR one you can see in the pics at the moment.
Sunk a good chunk of time in yesterday.
Finished off the power steering lines and pump in place.
Time to drop the engine in.
Triple check the rigging while stand still attached to make sure it holds up while hovering the engine over the car.
Engine in!
Looking good Paul. Now the fun bit.... the gearbox :D
Haha yeah looking forward to it .... I have a 500kg trolley that should help the cause a bit.
Need to get the flywheel machined first then the shenanigans begin.
  • 2 months later...
Getting things rolling on this again now I have recovered from everything else. Aiming to have it started within about the next 4 weeks.
Sammich plate is on, flywheel sent off for machining yesterday should be back today.
Clutch and gearbox should be back in over the next few days
Flywheel, clutch, gearbox and starter are in.
Freshly machined flywheel fitted and torqued up.
Then realised being a new engine it was missing the pilot / spigot bush in the end of the crank.
Picked one up and installed and flywheel back on.
Clutch on. Its an Xtreme unit I already had in the car, handled ~300rwkw so should still be up to the task.
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
