You can all get stuffed. Last night after speaking with Paul I went home and had a hard look atht wheel pricing and figured I wont be hapy until i get them for mine. So once the rebuilt shocks are paid for its time for some 18x10 +35 & 18x9 +25s for my bus. As for you mob with your GTRs...jog on!
:blink:
Oh ... I just went home and ordered a set of them - they are on their way to me as we speak ... you will no longer be a unique snowflake.
(just joking, getting TE's :unsure:)
So the engine bay is DONE! Nismo AFM's in, intake re-assembled, air box sticker charged and intake ducting cable tied down.
Also picked up some rebuilt stocky rear brakes in great nic
And pulled out my mad photoshop skills to confirm that in fact yes, as Anthony put it - black TE's will look tits. Particularly when filled with rotor and AP goodness. Borrowed an 18x10 rotor TE copy toying with the idea of grabbing them as a spare set for slicks but still a bit undecided - I don't think my guards are pumped quite enough.
I am chasing some stock front calipers + rotors + pads + lines if anyone knows of any - preferably in Melbourne. Just as a temporary solution, rotors can be at limit and pads almost gone, just no caliper / line leaks.
Bay looks sooooooooooooooo schmick man. Better than brand new!
Did you run new OEM Nissan front and rear window seal kit..........? Pics with no masking tape.....?
Black TE's will set it off!
FYI - http://www.skylinesaustralia.com/forums/topic/414449-r32-gtr-intercooler-shroud/
Cheers man! Nah just an aftermarket seal front and rear - it's not perfect at the corners but the urethane seals everything up really well.
Tempting group by is tempting - interested in the OEM wing in carbon..... hmm
Picked up these 18x10.5+15 from Import Monster - off getting stripped and painted matte black for the 34 so 32 will have wheels in a week or so. They will definitely get the obligatory test fit on the 32 once they are ready of course for the stance shot before the sensible sized wheels go on.
Wheels back from being painted matte black, the 10.5's actually sit pretty nicely at this ride height. Will get the same treatment done for the 9.5's soon.
Dash chopped to accommodate the cage and gearstick refitted. Have started to fill up some fluids and check over lines etc.
Getting close mate....you must be on edge. Car looks dangerously good, keep photos coming!
Any chance you could post some photos up fo the new front and rear window seals...
Also, did you run new rear quarter windows?
Great build.
That looks awesome. You must be wrapped. Hope the rest goes well!
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
