The mrs got some vids of turn 12/13 on to the main straight. If only every day was a track day.
Spoke to you at Sandown on the 13th of October definately have
a nice R32 GTR there , the GT3 Porsche could just not keep up with you .
G'day good chatting. Hopefully catch you at the track in your own 32 soon!
Cheers - yeah the second time I got out which the second vid is from it stopped raining and the track started to dry out towards the end, times started to drop. Still wasn't enough to get a feel for how it will behave in the corners and under heavy braking but I will get there.
Got my eye on a Winton test n tune on Friday...
Hit Winton today - much better than Sunday, satisfied now.
Car held together well, have a few suspension changes I would like to make to start firming it up as the suspension is still very much Tarmac Rally orientated.
R32 ABS is also really annoying on the track, time for it to be deleted.
Best for the day was a 1:35.5 which I am very happy with for its first real outing.
Everyone loves the flames... but not sure I will enjoy having to clean this off each outing though... bring on E85
Posted Image
very nice driving Paul.
So pleased to see it's going well on the track.
I'm taking mine to QR next weekend :)
Yeah ABS is a pain on the track.
You must be spitting some pretty nasty flames to BBQ that rest lol
Really nice car - identical to mine except for the stripped interior, awesome paint work, exceptional cage, and a million other things. Although you need to beat this flamage for true glory! :yes:
needs to be a bigger pic size man!
Ha the boys were explaining it in similar dimensions so I may be able come close.
I saw your 32 years back in ashburton. Jealousy levels were high - you still get it out to the track ?
not for a couple of years, my wife opened a can of whoop ass when our third baby was born so it was back to racing bikes with all the other MAMILs. I will never sell it though, its awesome as you would appreciate with your beast. I'll sneak a track day here and there I hope.
  • 5 months later...
Vid from Sandown yesterday, best for the day was a 1:20.4.
ABS unit still causing issues with the brakes, spongy / inconsistent so on a mission to remove that shortly along with some suspension tweaks to try clean up the braking. Also a bit of ducting for the radiator needed - yesterday after about 3 harder laps it would hit 100c water and 120c oil and sat there, add some ducting to force a bit of air through and I reckon it will be a very nice solution.
A bit of a brain fart at turn 11 deciding which gear to use and so still chasing that elusive Sandown teen, one more session would have been nice but a guy smashed his porsche. Should be an '18 in it with me driving after a few tweaks. Regardless this 32 is a whole lot of fun to drive :)
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
