In all it's glory - following for AC's 1:25 then my creative line through 1
bout bloody time you overtook that pesky R31 Paul :P
Great onboard footage and nice driving mate :thumbsup:
PS your Nismo tachometer is disconnected because your using other means to track your speed aside from the electronic tachometer displayed?
Yeah the speedo cable broke recently so in the process of getting another one. Hopefully cable isn't too hard to R&R, but I am guessing it will be...
im not sure on that one Paul but I can't imagine it being as much as a PITA to change compared to changing / replacing a clutch and gearbox
  • 3 weeks later...
Hehe nah all good Ant's, I only push the braking markers where I have run off, pretty much T1 only at Sandown. Always able to wash off enough speed.
Tyres were too hot after a couple of faster laps and just didn't want to turn in, so I decided to straighten up and was going quite slow once I actually left the track. Brakes are unpredictable too with the ABS unit in there, really inconsistent so once I sort that.
  • 3 months later...
Sandown yesterday, cracked into the 19's. Can certainly see more time in there too which is good - particularly around the sweeper (and fixing the ABS issues!).
Put some high density foam around the radiator which works a treat, big difference. Could keep going for the entire session with water temps not getting any higher than 90c and good oil temps. Going to get trackart / Andrew to make up some proper alloy ducting and it should be good all year round. So I am happy with the oil cooler sitting in the radiator end tank - seems like a good solution and easy / tidy from a packaging perspective.
  • Like 4
very nice Paul
Was the radiator moving around before the foam was installed causing the increase in water temps?
very nice Paul
Nah just air escaping around the sides and top and not passing through the radiator. More is now forced through the radiator. Can definitely improve further with some proper alloy ducting, would probably just want to knock another 5 or so degrees off max water temp, oil was happy around 100-110c. The ducting would bring both down a touch.
Paul, sub 1.20s is getting quick. Well done. Be interested so see the rad set up you're considering as track temps are always an issue...Maybe let me know when you're down at Trackart next as I've got to go there too?
Cheers.
Cheers.
Cheers. Got a touch more weight I can take out here and there. Compliance intrusion bars being an obvious one, could also do carbon / glass boot lid and wing. Don't need the passenger seat & mount either.
Hence why I reckon an 18 would be achievable with a few tweaks. Can see time in my driving as well, but you know... always good to leave a bit of fat make sure you bring it home in one piece!
There would be some easy time had in moving away from the stock diffs and modifying the transfer case but happy to get there on a standard drive line from the gearbox on for now.
For sure will let you know re: track art.
Paul
did u retain factory power steering? I am looking at a EPAS electric kit for my build.....any thoughts?
Do u find the steering really heavy when tracking the car and the front wheel drive is engaged. Almost to the point of being exhausting after five or six laps at pi?
Thinking the epas kit will strip a fair bit of weight and maybe give me a better overall steering package? What do you recon?
Cheers.
take her to PI paul. Cant wait to see your time there!!!!
Paul
Yeah steering is quite heavy - still factory, I think because of messing with the HICAS it no longer lightens up at lower speed. It also seems a bit variable - seems to get quite heavy for no obvious reason.
Just watched an EPAS vid would be a nice solution for sure. Could definitely cut down some weight there getting rid of the reservoir & pump etc.
And yeah itching to have a crack at PI with it, will be good fun!
Yes mine get heavy for no apparant reason. Some times it is like u have to wrestle the car at PI.
I am definately going to do something funky. At the very least an mr2 electric hydraulic pump plumbed into the system.
Maybe a full electric servo system like epas. This looks to require a whole new manual rack though.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
