In all it's glory - following for AC's 1:25 then my creative line through 1
bout bloody time you overtook that pesky R31 Paul :P
Great onboard footage and nice driving mate :thumbsup:
PS your Nismo tachometer is disconnected because your using other means to track your speed aside from the electronic tachometer displayed?
Yeah the speedo cable broke recently so in the process of getting another one. Hopefully cable isn't too hard to R&R, but I am guessing it will be...
im not sure on that one Paul but I can't imagine it being as much as a PITA to change compared to changing / replacing a clutch and gearbox
  • 3 weeks later...
Hehe nah all good Ant's, I only push the braking markers where I have run off, pretty much T1 only at Sandown. Always able to wash off enough speed.
Tyres were too hot after a couple of faster laps and just didn't want to turn in, so I decided to straighten up and was going quite slow once I actually left the track. Brakes are unpredictable too with the ABS unit in there, really inconsistent so once I sort that.
  • 3 months later...
Sandown yesterday, cracked into the 19's. Can certainly see more time in there too which is good - particularly around the sweeper (and fixing the ABS issues!).
Put some high density foam around the radiator which works a treat, big difference. Could keep going for the entire session with water temps not getting any higher than 90c and good oil temps. Going to get trackart / Andrew to make up some proper alloy ducting and it should be good all year round. So I am happy with the oil cooler sitting in the radiator end tank - seems like a good solution and easy / tidy from a packaging perspective.
  • Like 4
very nice Paul
Was the radiator moving around before the foam was installed causing the increase in water temps?
very nice Paul
Nah just air escaping around the sides and top and not passing through the radiator. More is now forced through the radiator. Can definitely improve further with some proper alloy ducting, would probably just want to knock another 5 or so degrees off max water temp, oil was happy around 100-110c. The ducting would bring both down a touch.
Paul, sub 1.20s is getting quick. Well done. Be interested so see the rad set up you're considering as track temps are always an issue...Maybe let me know when you're down at Trackart next as I've got to go there too?
Cheers.
Cheers.
Cheers. Got a touch more weight I can take out here and there. Compliance intrusion bars being an obvious one, could also do carbon / glass boot lid and wing. Don't need the passenger seat & mount either.
Hence why I reckon an 18 would be achievable with a few tweaks. Can see time in my driving as well, but you know... always good to leave a bit of fat make sure you bring it home in one piece!
There would be some easy time had in moving away from the stock diffs and modifying the transfer case but happy to get there on a standard drive line from the gearbox on for now.
For sure will let you know re: track art.
Paul
did u retain factory power steering? I am looking at a EPAS electric kit for my build.....any thoughts?
Do u find the steering really heavy when tracking the car and the front wheel drive is engaged. Almost to the point of being exhausting after five or six laps at pi?
Thinking the epas kit will strip a fair bit of weight and maybe give me a better overall steering package? What do you recon?
Cheers.
take her to PI paul. Cant wait to see your time there!!!!
Paul
Yeah steering is quite heavy - still factory, I think because of messing with the HICAS it no longer lightens up at lower speed. It also seems a bit variable - seems to get quite heavy for no obvious reason.
Just watched an EPAS vid would be a nice solution for sure. Could definitely cut down some weight there getting rid of the reservoir & pump etc.
And yeah itching to have a crack at PI with it, will be good fun!
Yes mine get heavy for no apparant reason. Some times it is like u have to wrestle the car at PI.
I am definately going to do something funky. At the very least an mr2 electric hydraulic pump plumbed into the system.
Maybe a full electric servo system like epas. This looks to require a whole new manual rack though.
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
