paulR32gtr Posted September 23, 2012 Author Share Posted September 23, 2012 Spent yesterday on the car, mostly tidying up but got a few things done. Removed these split HKS dumps ... And replaced with this Midori setup. Biggest off the shelf dumps I could find, and the front pipes are pretty big compared to the JustJap ones I had on previously. Biggest in a two bolt flange. They have really thought about the design on the Midori's, really easy to get to all the nuts as opposed to the HKS where I needed three different 12mm spanners for the nut at the back of the front dump. Also rebuilt the clutch master with a new piston kit from Nissan. Really simple, two circlips, a good clean and check of the cylinder and back together with new bits. Comparing pistons easy to see why it was leaking. New piston in. All back together and on the car. BBQ fired up, triple level bbq burgers with the lot with an integrated egg / toasted bread centre layer and a couple of JD's - golden. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6546242 Share on other sites More sharing options...
paulR32gtr Posted September 23, 2012 Author Share Posted September 23, 2012 Have a spare full R34 battery cable / tray / fusebox setup so replicating the setup on the R32. The riser into the engine bay doesn't quite work with the R32 so modified one of the brackets a bit to bolt to the same spot as the speedo cable. Will do some more work around here to make sure its locked down and doesnt interfere with anything else. Rivnuts all the way. Shape along the rail is identical. I lined up where the rail tapers out towards the front and the rest falls into place. About the right amount of length up engine bay end. Existing hole in the boot matches the standard R34 grommet. Rear of the rail brackets fit in pretty well here too. Up over the tailshaft. Bit different here so I may even go direct to the boot and size the cable down accordingly. No need for it to be longer than it needs to be. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6546848 Share on other sites More sharing options...
R31Nismoid Posted September 24, 2012 Share Posted September 24, 2012 Looks like the hole cutting went really well Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6548836 Share on other sites More sharing options...
paulR32gtr Posted September 25, 2012 Author Share Posted September 25, 2012 Yeah was a little nerve racking but measure three times, drill once! More to come once I mount the battery tray and run the kill switch circuit in the cabin but that should be the extent of it. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6549074 Share on other sites More sharing options...
Miguelone Posted September 25, 2012 Share Posted September 25, 2012 How are you going to sit the positive end of the battery cable in the bay? My 33 has the battery under bonnet and I'm going to be putting in one of those cables like you are, just can't work out how I'm going to sit all the positive ends without it being dodgy or earthing out on the body. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6549778 Share on other sites More sharing options...
paulR32gtr Posted September 25, 2012 Author Share Posted September 25, 2012 How are you going to sit the positive end of the battery cable in the bay? My 33 has the battery under bonnet and I'm going to be putting in one of those cables like you are, just can't work out how I'm going to sit all the positive ends without it being dodgy or earthing out on the body. I have the standard fuse / relay / distribution block spare from an R34 GTR so I am going to try to use that instead of the standard R32 GTR one you can see in the pics at the moment. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6549783 Share on other sites More sharing options...
Miguelone Posted September 25, 2012 Share Posted September 25, 2012 Cool, will be keen to see results. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6549977 Share on other sites More sharing options...
355GTS Posted October 6, 2012 Share Posted October 6, 2012 I am going to do the clutch master as well I think. Good idea. Burger looked the goods as well Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6567344 Share on other sites More sharing options...
355GTS Posted October 6, 2012 Share Posted October 6, 2012 Now I look back over your thread I am even more impressed at the attention to detail Paul. Nice work. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6567353 Share on other sites More sharing options...
paulR32gtr Posted October 20, 2012 Author Share Posted October 20, 2012 Sunk a good chunk of time in yesterday. Finished off the power steering lines and pump in place. Time to drop the engine in. Triple check the rigging while stand still attached to make sure it holds up while hovering the engine over the car. Engine in! Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6588116 Share on other sites More sharing options...
Piggaz Posted October 21, 2012 Share Posted October 21, 2012 Looking good Paul. Now the fun bit.... the gearbox Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6588154 Share on other sites More sharing options...
paulR32gtr Posted October 21, 2012 Author Share Posted October 21, 2012 Looking good Paul. Now the fun bit.... the gearbox Haha yeah looking forward to it .... I have a 500kg trolley that should help the cause a bit. Need to get the flywheel machined first then the shenanigans begin. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6588187 Share on other sites More sharing options...
Piggaz Posted October 21, 2012 Share Posted October 21, 2012 Dont forget the sammich plate. Haha! is it going to be on E85 at any stage? Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6588264 Share on other sites More sharing options...
paulR32gtr Posted October 21, 2012 Author Share Posted October 21, 2012 Yep definitely noted on that one! Yeah plan is to go for a link g4 at some point with the sensor so I can run what I've got. Not sure if it will make the first cut but definitely the plan. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6588307 Share on other sites More sharing options...
paulR32gtr Posted October 21, 2012 Author Share Posted October 21, 2012 ... will also need a different pump maybe and injectors - nismo pump with sard 700s atm Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6588311 Share on other sites More sharing options...
dougie Posted October 22, 2012 Share Posted October 22, 2012 awesome build. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6589808 Share on other sites More sharing options...
$$slowmedown Posted October 22, 2012 Share Posted October 22, 2012 Dear God, it's beautiful! (Zoolander) Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6590296 Share on other sites More sharing options...
krzysztof Posted October 23, 2012 Share Posted October 23, 2012 i am re-building a silver 33 GT-R to similar standards so really appreciate what you have there keep up the great work! i wish i had more time on my hands to progress with mine Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6592528 Share on other sites More sharing options...
paulR32gtr Posted January 9, 2013 Author Share Posted January 9, 2013 Getting things rolling on this again now I have recovered from everything else. Aiming to have it started within about the next 4 weeks. Sammich plate is on, flywheel sent off for machining yesterday should be back today. Clutch and gearbox should be back in over the next few days Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6699632 Share on other sites More sharing options...
paulR32gtr Posted January 15, 2013 Author Share Posted January 15, 2013 Flywheel, clutch, gearbox and starter are in. Freshly machined flywheel fitted and torqued up. Then realised being a new engine it was missing the pilot / spigot bush in the end of the crank. Picked one up and installed and flywheel back on. Clutch on. Its an Xtreme unit I already had in the car, handled ~300rwkw so should still be up to the task. Link to comment https://www.sau.com.au/forums/topic/328473-pauls-r32-gtr-track-build/page/7/#findComment-6707818 Share on other sites More sharing options...
