These wooden wheel stands are a massive help - had to get the car high enough to get the gearbox underneath on the hydraulic trolley.
Getting closer.
Are you too good for your home?
Bit more gentle coaxing and playing around with angles and shes apples. First time I have fitted up a gtr gearbox, was a bit painful but got the drill down pat now.
Starter fitted up.
And cross member in.
ATTESA reservoir & lines through to the gearbox are in, tail & front shafts are in and bolted up. Entire drive train minus the drivers drive shaft in.
Front pipes on and played around a bit more with battery cable routing at the front where it ducks around the chassis rail. Looks like I can use more of the 34 bits than I thought - should be pretty neat once finished.
Also spent some more time on hooking up wiring in the engine bay.
Can almost see the end in sight.
Haha ok ok - tail shaft & 90mm front pipes. Dug out my old Trust PEII cat back and high flow cat to see what size they are. Not big enough - going to have to organise a new exhaust thinking Midori titanium. May even get the titanium Midori front pipes as well as I might need these ones on my other car due to a few issues. Wanted them originally but heard reports of titanium front pipes cracking - others seem to be using them successfully from what I have seen though.
Fuel tank went in yesterday.
Then started hooking up the cabin to boot wiring. This threw up the first issue with the battery relocation. The hole that works so perfectly is actually for passing through the 4wd pump wiring so I need a new solution to rise the battery cable into the boot. I left enough slack on the cable in case I ran into trouble like this so might bring it through behind the battery to keep it out of sight and neat.
Battery cable hole made and painted, mirrored the one on the other side and looks factory.
Cable through and battery tray back in.
Battery back in place.
Also spent some time on my least favorite area of any skyline - the drivers foot well / fuse box / loom junctions. Got most of it hooked up but need to repair a few of the wires that were cut when the alarm system was installed and subsequently removed.
Not a great deal to report. Waiting on an HPI braided clutch line so I can simplify and do away with the factory dampening system and get the slave cylinder back on and everything hooked up.
Put a new dust boot on as my old one had gone walkabout. Having serious trouble finding the bolts that mount the slave cylinder going to have to source some replacements.
Also got some new fuel hose to replace the old split ones.
Got back on to the routing for the battery cable to get it finished off. Dunked some of the R34 mounting brackets in Phosphoric Acid to get some corrosion off, and hit them with some chassis black chip resistant paint.
In the bay along the rail there was an existing captive nut left over from the rear HICAS gear removal so mounted up nicely. Almost there on the rest of the bracketing.
Cable now ducks around the chassis rail using the R34 bits and works quite well. Just need to finish off the part around the steering and good to go.
Clutch line should be here tomorrow. Then I just have a few other bits buried in the sands of time to track down so I can progress.
  • Like 1
Thanks and thanks to everyone else who has commented! I've been having a lot of fun putting it back together - can't wait to see it fire up for the first time.
Had a thought last night the clutch slave bolts are probably in the starter motor, and the other 35mm ones I have left over are for the starter ....
Watching.....
I was just looking closer at your cage and noticed you did a double cross in the rear tubes. I only did a single tube diagonal in my 32. Now I am jealous of your cage......looks great. I might send mine back for some extras once I have raised some more money......
I would say it's just Andrew evolving what is required / works. My R34 only has the single cross in the rear same with the one I bounced several times on its roof and that held up very well :P
My main concern is retaining the standard dash bar. If this was being used for rally still, I would probably do a dash bar with some more tie in to the trans tunnel / firewall just to keep that engine out of the cabin & keep good space for legs.
I believe I need the Sainz bar as well now to be able to log book / register the cage so will need to get that added at some point.
looking great Paul. Did racepace build the motor or did you do it yourself?
Yep Racepace built the motor. It's a stage 1 / 2.6. I sourced a new N1 block, R34 crank, Tomei oil pump, injectors etc and we used the head from my engine, rebuilt of course and the ancillaries. Turbo's are GT-SS that I already had on there that have only done 10K kms or so.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
