Hi Guys, just got myself some RB74 from DBA and also, some printed instructions on how to properly bed the pads. The RB74s are notoriously famous for squealing but I had no problems with it after following the guide. Thought I share it with you all because I am pretty sure that its applicable to all new pads. :(
BEDDING IN INSTRUCTIONS
1. Install disc pads and check fit.
2. Pump brake pedal until pedal is hard.
3. Perform 2 stops from 50Kph to 20Kph with medium pedal effort.
4. Perform 6 stops from 110Kph to 70Kph with high pedal effort.
5. Drive vehicle for 10-15 minutes at 70 to 100Kph without using the brakes to allow them to cool
6. Park vehicle and allow brakes to cool to ambient temperature.
DO NOT STOP VEHICLE WHEN PADS ARE HOT DURING BEDDING.
THIS WILL SEPARATE THE PAD FORM THE BACKING PLATE
Bedding should not be performed until disc rotor has been bedded.
The disc pads will smoke and smell whilst bedding.
btw, the pads rock!! :( They grip very well and even after a very hard drive with equally hard braking involved, i hardly noticed any brake fade at all.
cheers
glenn
https://www.sau.com.au/forums/topic/32849-brake-pads-bedding-in-instructions/
I just had new discs/pads put on my '32 and was wondering (if it's not too nosy) what you guys paid for your pads, coz i had to skimp a bit on the pads after paying for the discs, and they don't seem to be doing as good a job as the ones i took off ! any thoughts would be great..
cheers, phil
My car had RB74s on it when i got it and they work really well, i have white wheels and have just given up on keeping them clean. Anyway, brake dust is the sign of a true street racer, or so ive heard. ;)
I also just got my discs machined for $100 the lot, after i could hardly keep my foot on the brake pedal as it vibrated so much. Work awesome now, almost forgot what it was like to be able to stop quickly.
PS how much were the RB74's?
My RB74's started to squeel a bit after about 1000ks when braking slowly from about 10ks to zero but other than that all good.
They do start to fade after alot of punishment, like midway through a runup the Old Pacific Hwy but even then they feel better than the dodgy stock pads
Greg, you will be able to find more info on RB74s and other pads as well on this thread. Dun worry about the RB74s, they dun chew into the disc but damn dusty.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=32932
  • 2 months later...
I use RB74 purchase from http://www.racebrakes.com.au/. Ever since I have them until now, which is like 10 km's. Its still make a horrible squeakie metal noise when stopping. Could someone advise me what to do or check? By the way I got a mate to install its, but i don't think he bedded !!!
Looking at the RB74 brake pad, i do see alot of chunk of silver + gold metal particles on the pad itself. It's that normal or i just got a faulty one? Compare to my original pad, it's much more finner particles, it's that why it squeal more noise than the original brake pad?
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
