2004 Skyline V35 350gt
  • Replies 52
Posted Images
Swap for my car plus cash your way? Check the link on my signature for more info.
Also, does this car have the pop-up sat nav factory option and dual zone climate control? And how many ks has the motor done? Anything remotely wrong with it that I should know about--any leaks, rattles etc.?
Pretty interested...
Edited by GT32
It does have the factory sat nav and dual zone climate control. The only thing is, I haven't converted
it to english. It's done 48000 kms. The only thing wrong with it is the front bumper. No leaks or rattles.
I get it serviced at Lister Automotive in Belmont. If you are interested in having a look at each others cars,
maybe we can catch up during the week or next weekend. I had a look at the photo's of your car. It looks
pretty tidy. Talk to you soon.
Ah ok, well we can have more of a chat once we see each others cars.
The body on my car is completely straight and hasn't been in any accidents in the 5 years that I've owned it. Front bar has a small lower lip crack though and body needs little touching up in a few areas. Other than that, the car is mechanically fine and runs well in the current state of tune (297rwkw@5800rpm/17.5psi). Engine has travelled around 8000kms since I've had it rebuilt so it's well and truly worn in and ready for the final tune with the new ECU. Minor oil changes and maintenance is done by me and major servicing, tuning and everything else is always performed at A.R.T. in West Heidelberg.
I would be willing to bring the car for you to have a look/test drive but the gearbox is currently in the process of being replaced due to the input shaft bearing getting noisy and 5th gear crunching more frequently. I've ordered a new gearbox from Japan over 2 months ago and the container has finally arrived in Melb last week. We still can't empty it until the middle of next week unfortunately so I won't be able to organise anything with you until possibly the week after once the new box has been installed. Price will still stay the same ($17,500) once this is done.
However, the new ECU (Power FC) and new boost controller (AVC-R) which has not been installed and tuned isn't factored into the price as of yet. I'll sell the car as is at the current price which is negotiable without these 2 items and without the Work rims. Or the price will be slightly revised if they are to be fully installed and tuned (Power FC=$1200, AVC-R=$700 is what I paid for these two parts and also tuning is roughly another $1000).
Let me know what your thoughts are and the cash adjustment amount you are wanting. I'll get back to you once the gearbox is done. Will be in touch very soon.
Edited by GT32
  • 1 month later...
Not for sale anymore due to lack of interest and too many wankers. I'm better off keeping it than getting f**ked around.
was in the same boat when i was selling my V35 end of last year; everyone for some reason things that V35 can be brought for free !!!!
understand that there is too many if them for sale considering the target market for imports
Look for a bumper in Import monster and get a red one, if you have the patience you will find one eventually, so you can fit it your self
  • 2 months later...
  • 3 weeks later...
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
