A RB30DET was a motor never offered by Nissan, it is illegal until tested... The test costs 3k, and if you fail that's it.
So clearly it will never be legal either :blink:
I don't know that the cylinder head effects the eligibility of it for compliance. The block is made by Nissan and all factory mounting positions are maintained. The do the same with V8's....HQ 308's never came with alloy heads but if you put one of those engines into a different car, they are still able to be certified regardless of cylinder head.
Honda is another example with the KA20? with 24 cylinder head or something. Pretty sure it's cylinder block related
Apparently changing heads from single cam to twin hurts the environment according to Victoria EPA.
In eyes of EPA in Victoria, twin cam RB30 doesn't exist thus the need for emission testing.
So clearly it will never be legal either :rofl2:
surly you wouldn't just roll up and ask for a cert? You would do some home work at least right?? There's always loop holes.
If you were to do something along those lines your be finding an engineer and Maybe for argument sake paying a few hundred extra to find out what can and can't be done and working with them.
It carnt be impossable you just have to make it save and pass the tests ect and if your wallets deep enough and you want an rb30 in your r33 then I'm sure it can be done!!
Personally I can think of much better things to spend to money on but hay ho
The reason no one bothered is as Ash pointed out the emission testing cost $3k, if you fail thats it.
If you want legally to have RB30DET, move to another state.
Well not really.
You have to basically go through the entire ADR emissions testing for Vic. It's not like NSW where you can just get a quick test and off you go (where you can get it pre-tested).
The equipment is not cheap, so for a "pre test" you'd probably be looking at close to the 3k anyway.
Its quite involved and it's not just 5mins on a dyno. It's the full testing in closed conditions for 20mins, road testing and whatever else goes on as part of ADR certifications for emissions standards...
Basically forget it in Vic for 100% legal is the theme here.
Dan - Ye to an extent, but they class it as 3ltr and SOHC falling into one emissions setpoint as a factory motor.
The motor you are making is not a factory offering, therefore there is no emissions data available to reference off. If Nissan made a RB30DET - you'd be sweet :rofl2:
Stuff all that crap. I'll just buff out his engine No. and stamp in my currently engine Number. Thanks guys.
X stamp the hell out of the old number first, then put new number on top. If they get that thing under X ray you'll be in more trouble than just a defect...numbers go right through the metal past what the eyes can see :)
What do you think it would cost to make up a spacer plate , fit it to the block and bore the "sandwich" for thin walled liners ? Paint the block keep your number and claim the 5th if questioned .
In with the 30 crank/rods/pistons and have a real torquey "RB25DET" .
Don't they all roll off the boat looking like that ?
A .
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
