isn't the only possible problem when the car changes hands? have any of you known of a cop to check engine numbers? lol
HAha yeah i dont even know where my engine number is and I've pulled it half to bits, so doubt coppers gunna notice, just register it with original engine numbers and then i guess play dumb if you get caught..
I traded in an old pathfinder years back and got a call a few months later asking me if i had changed the engine, I knew nothing and had only ever changed the head,but apparently it was a stolen motor from another state so Vicroads didnt pick up on it 'but when they went to sell it in another state it showed up..Some poor guy had bought it and it was impounded on him when he went to get a roadworthy in SA..Well that was there story, load of BS i reckon cause i seen the car a few months later in Dandenong
Seriously how many people actually check their engine number, very few i bet ,hell alot of people dont even know how to open the bonnet..usually just go by the ID tag on the body..Unless your going over the pits whos gunna know...
Edited by Arthur T3
Easy to do, no cop will tell you got an rb30 if you got a rb25 head on there. They dont know that the engine is a bit taller. Vic roads are dumb too. Like what we did we my brother engine conversion.
Me: Hi, i would like to get my engine number changed, the last motor blew up and we just did a swap
Vic roads lady: Oh alright, is it the same engine
Me: Yes ( :D )
*Goes and gets engine number off block*
Vic roads lady: Great can you just fill in this form and sign here
Me, Yeap no problems, Cya later
Me: Yes ( :D )
If you ever have to have a full inspection due to defect etc you will get caught out on that one. The guys that look at the skylines are pretty clued on and would pick that straight away.
had to go to the pits in my proton, it had a Mitsu MIVEC 1.6 in it never changed over
poped the bonnet, ohh yeah looks good dont even have a pod on there... nar man they are gay :woot:
puts the bonnet back down all good :woot:
didnt look at the numbers, didnt even nitice that it said Mitsubishi MIVEC on the motor and it was a Proton M21 coupe??? lol
Oh I dunno, a mate got his HR31 registered with a NEO motor in it in Victoria, the woman even went out and read off the engine number and entered it into the system LOL
Yeah the numbers inspection places don't usually notice anything unless you get a guy who knows the nissan engine codes, I went in for one in my R32 skyline planning to have a full inspection (since passed) and they stamped red stamps all over the form saying no compliance plate, engine capacity increased by 25% needs full roadworthy, was no way of getting out of that one.
During the inspection being a skyline they had 3 guys shining torches in every crevice of the motor making sure the carbon canister was attached, injectors were standard, even knew what colour the AFM sticker was meant to be, he even picked that I had a new turbo on there, but couldn't prove it as it was a highflow, the only thing they didn't do was open up my ECU and check inside.
Apparently changing heads from single cam to twin hurts the environment according to Victoria EPA.
In eyes of EPA in Victoria, twin cam RB30 doesn't exist thus the need for emission testing.
The EPA totally knows what it's on about:
http://epanote2.epa.vic.gov.au/EPA/Publica...6;FILE/1031.pdf
Page 8, section 7:
"An engine management system enables the engine to function with minimum emissions under a wide range of operating conditions. It also uses a variety of sensors to optimise combustion by altering how the engine operates, thus maximising fuel economy, engine power and engine life. A system that is not designed specifically for the engine it is fitted to is likely to increase emissions, reduce engine power, have poor fuel economy and reduce the life of the engine."
That's right people! Your APFC or E-Manage is the reason you have no power! :rofl:
I think they are talking about using a factory ECU from another motor, eg an rb20 ecu on an rb25 etc with no tuning done. I doubt it would even run but if it did then what they said is completely true.
Yeah mate, I got that idea too, but it just read funny out of context. And that's the only reason they give against aftermarket ECU's.
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
