Ladies
Did an oil change on an rb25det, didn't run a flush though it and replaced oil etc. Car was driving fine and then all of a sudden it sounded like a wrx, started ticking and all the rest of it.
Firstly I thought it may have been a lifter that was sticky something getting jammed near it causing it to run on 5 cylinders. So I ran the nulon "lifter free" additive and that didn't change much.
Upon closer inspection I noticed the ticking was coming from the back, on the exhaust side. So I drove the car home and checked out the plugs and this is what I found.
You can see the white residue on the rocker cover and also on the side of where the packs would sit. No. 5 seems to be the issue here, as the pack has melted around the plug and the clip that it goes into has also melted.
As I said before the ticking is coming from the exhaust side, could this be a faulty exhaust gasket? If so, how would I check it?
So basically I need second hand ones of everything in the photo, minus the plugs and the cover. If anyones got some that would be great!
If I fix this issue with working parts could there be another issue in cyl 5 / 6 that may have something to do with this?
https://www.sau.com.au/forums/topic/328585-rb25det-sounding-like-a-wrx/
exhaust gasket will have nothing even remotely to do with it.
generally i've found oil additives are a waste of time. if theres a serious problem it will never be fixed by tipping a little something into the oil filler.
before you go replacing parts and just shoving them back on you might wana have a little investigation as to how it got so hot in there to melt the coil pack and loom like that. what plugs where you using?? my best guess as to the white crap everywhere could be porcelain off the plugs, as by the look of that plug it has been very very hot and the more i think about it the more i like that theory.
first things first you need to find out how the hell did cylinder number 5 get so freaking hot as to cause all that. thats obviously what caused the running on 5 cylinders and hence the engine sounding different
Edited by jonboy
actually after having thought a little more about it, sounds to me like you could have a broken valve, if its bent out of shape or something that could explain the excessive heat generated through the plug as well as the ticking noise as the valve wont sit properly on its seat.
do a compression test. if compression is way down on number 5 then thats almost certainly your problem.
if so, time for the head to come off
Edited by jonboy
Don't know what burnt your gear but the ticking is quite normally for a cylinder that isn't igniting...just have a quick look at the top of the piston and the spark plug thread. Replace coilpack / spark plug and probably that loom. It looks like something shorted or didn't have a good earth? Never seen something like this before...it's almost like the spark plug came loose and the combustion started breaching the cylinder bore with exhaust/flame? Very queer.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
