Hey,
I have a manufactured roll cage (its not custom) and on the padding there is a sticker that sais Kagura. I Can't find any information on it and I need to find the material its made of and the wall thickness of the tube. Its a 6 point cage with an off white padding. The tube size is 40mm
Can anyone point me in a direction?
thanks
https://www.sau.com.au/forums/topic/328589-kagura-roll-cage/
what is your intended use? cams racing? AASA racing? ANDRA thingy?
among other things, CAMS require the main hoop to be 45mm with 2.5mm thickness, or 50mm with 2mm thickness. Other members carn be 38mm 2.5mm thick or 40mm with 2.0mm thickness.
Assuming it is a japanese bolt in cage it almost certainly doesn't meet the CAMS requirements. Also watch out for the design of the A pillar mount - if it has more than 1 bend at the windscreen it is not legal (most around the dash cages don't comply as they have an S shape.)
ok, thanks for that information. Its just a weekened car. I live nowhere near any tracks and my mates and I drive 1000km south to brissy for friday night drift nights at QR every few months. I am just trying to get the cage engineered for a mod plate. I spoke to a guy and he said I need to find the specs to see if he will approve it.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
