- GTR intercooler, has been acid dipped/cleaned and polished. Top & bottom shrouds have dents but core in good condition. Sell $750.00 (Receipt for $970.00, open to offers)
- R32 GTR fibreglass bar - $450.00 (NEW $595.00)
- JVC KS-AX 6700 2 channel amplifier, was only in car 4 weeks until rear strut brace dictated removal of sub. Still have box and packaging. Amp is unmarked. As reviewed in March 2002 Hot 4s. 302WRMS bridged @12V
New $700.00, sell $400.00
- RB20DET Inlet Manifold, no throttle body injector rail etc, Sell $150.00
- Factory GTS-T R32 intercooler with some piping clamps and hoses - $100.00
Will consider offers on all items or possibly trade
https://www.sau.com.au/forums/topic/3286-fs-gtr-intercooler-audio-gear/
Tell me the number of tubes the R32 vs R33 GTR cooler has and ill be able to tell you which i have. I think it has 24 tubes in total?
The amp is still for sale, if you buy the amp you get the deck for nothing, as after testing it the other night it would only play about 70% of CDs that i was trying. It may need a clean or laser replaced, (sitting in a box for 18 months i suppose). Good deck someone should be able to get use out of it.
The cooler fits the front of an R32 GTST with cutting to the bar.
On the weekend i trial fitted the cooler to an R33 with a 400R bar and there was miles of space.
As it is the factory GTR cooler i cannot think of a reason why it wouldnt fit an R33
Roy...
Can you give me a price on....
Front bar (the GTR replica for the R32 GTST)
Intercooler.
If you can give me a good price I might be able to get the money together..
If I buy both, will you give me a better price?
I'm also in sydney (ashfield area)
thanks
I tried to send this to you in a PM but it says that your pm box is full.
time for a clean up buddy.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
