Mate,
Let me tell you a secret. Dun even worry about them being able to be hooked up to our V35s, the fact is that these cams are crap....
The 1st one I bought...after parking the V35 in the sun, the front glass piece fell off...and after a while, the black anodised layer faded away....then finally, the humidity that built up during cold mornings killed it...
I then bought a 2nd one (different brand) with a revised cam housing so that the glass would not fall off..guess what? it died in 2 days...i suspect that everytime i went to change gears, it had to pass REVERSE, which then turned the cam on, and may have shorted out a resistor or something..
Verdict? I won't bother if I was you....
I bought a Panasonic camera similar to the look of this ONE that works better than the OEM one. Much better visibility at night. But it was $300 (even when bought in Japan)
The one in this link looks good but I can not speak for the quality.
The key thing is you need one that outputs in NTSC.
Cheers
Andy
