Micolour Sauvic Deca Motorkhana - Round 3!
Belsil80
 Share
  • Replies 234
SOLD - Email Sent. Payment on its way!!
Undeterred by the rain of last! I like your style :D
Paid & faxed. Cyas there!
ohh also, my asaa license expires 4 days before deca, how do i renew it??
If you have time, sort it out directly with them now so you have enough time to get your renewal sent out to you.
Its not preferable, but I can take it on the day if I really have to.
Faxed the forms through earlier this arvo. I did make a mistake on them though. The rego should be "*** 655" not what I put down lol hope it doesn't cause a problem lol :/
Below is the link to the June Results. After finding a mistake with Car 6's results the final finishing position were changed.
OVERALL TOP 3
1, Matt Femino
2, Chris Stacey
3, Dean Taylor
AWD Winners:
1, Matt Femino - GTR
2, Chris Stacey - GTR
3, Dane Stokes - STi
RWD Winners:
1, Dean Taylor - Porsche
2, Ryan Bell - Sileighty
3, Jamie Lovett - Porsche
June Results - Revised
OVERALL TOP 3
1, Matt Femino
2, Chris Stacey
3, Dean Taylor
AWD Winners:
RWD Winners:
Robbed!!
Well done Chris :D
can't beleive i haven't seen this post. emailing forms tonight.
dont think i'll bring the silvia tho, i'm actually getting body work done at the moment. so head's up first holden ute at SAU deca that i know of :D
time for stiff springs and front brakes that work.
d.
d.
I think you will find there is a SS ute already entered....
well well mine's not super sick, just sick, i didn't check the entry list before i posted. i was going to enter in march aswell but i still had a cast on my leg.
meh
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
