fantastic description kjb r33, thanks, i had wondered how it worked on an atomic level and you confirmed a few thoughts id had. cheers
Haha I didn't know you were running on 5?
literally half the time mate, and it's my daily :thumbsup:. has been raping my fuel economy haha. ecstatic about getting new coil packs! imagine driving without fear!!
The coil would start working with temp as heat makes things expand, a broken internal wire for instance doesnt touch cold, get some heat in and now it contacts.
my conditions are similar, the car doesn't misfire once warm, and i dont mean oil is warm, i mean really warm. I feel it is the coilpacks, they probably take some time longer than the engine to reach equilibrium temperature. If I leave the car for 8 hours after a drive it'll missfire, and does every day on the way to uni (30 mins). but if i drive for say an hour it figures itself out.
It also only starts to misfire when i back off throttle, or at idle. and once it starts, the tcs, slip and engine lights turn on and the misfiring continues for several minutes at least, before eventually recovering.
It's a game I won't miss playing... just hope I haven't done any damage, it's been like this for months :|
Edited by Galois
  • Replies 53
lol atleast yours is misfiring, mine plain wasn't firing...nothing like the rich smell of fuel coming out of exhaust pipe and the shaking of the car :thumbsup:
ahhhh, ok, so misfiring isn't a generic term for firing problems...
yeah mine was doing that, it's the worst feeling in the world, and a bit embarassing, though most people think that sound is intentional.
Sucks being down to like 40% power
My replacement YJ arrived today :D
Thanks Paul!
If you're just wanting to order, Galois, you can order them from eBay as PW are on there with listings up.
Yep, IT'S ALIVE! Starts on 6 cylinders everytime. Turbo seems to spool faster too, perhaps the faulty coil was performing poorly even when it was firing 6 cylinders.
Dunno, I didn't ask. They probably will examine it though. I don't really care as long as my car is running :D
Probably a loose connection inside, manufacturing fault maybe? I doubt I would have burnt it out without damaging the others. Let us know how your coils go.
omfg the new coilpacks make it so rev happy! I have disconnected the stock boost controller to bring it back to a safe 7psi, good for the slipping clutch and was good for the misfire. Reconnected it and man, rev happy + 13-14 psi was insane!!!!!!
You were right when you said they make a massive difference mate!
Now to get the clutch done. I want to connect the stock boost controller to a switch in the cabin (however the hell i do that), was thinking along the lines of one of those missile fire switches in jets mounted on the gearstick, subtly somehow hahaha. For now I have a switch and wire and need to find a hole in the firewall
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
    • Yeah I spent close to a year finding one. I was even tempted to buy a RB25DE N/A head and port it out. That latter option, could still be an option.
