R32 GTS-t
141,XXXkms on shell
can paint from a year or so ago
panels are all straight etc, wouldnt be hard to repaint
It's a 93 with rb20det manual set-up
Exedy Heavy Duty Clutch
Full Jap Exhaust
Chip Torque Chip
Turbosmart Boot Controller Boost-T
Blitz white faced boost gauge
Pod Filter
FMIC
Brand New Vertex Kit and spare standard front and rear bars
RX7 Series 6 Rims and stock rims
White Leather Isotta Steering Wheel
Handbrake & Boot
Tinted windows
Lowered King Springs with Bilstein Adjustable height shocks, was running coilovers but i prefered this set-up for street, certainly has no body roll tho, stiff ride
Would go back to coilovers if was going on track tho
Full Whiteline Suspension Kits with Neoprene bushes throughout including:
-Upper & Lower rear suspension camber kits
-Front Suspension Caster Kit
-Front Suspension Camber Adjustment Kit
Adjustable Front and Rear Heavy Duty Roll-bars
Rear Diff Alignment & Squat Adjustment Kit
Front & Rear Whiteling Strut Braces
GTR Brakes - GTR cross-drilled front discs with GTR calipers
GTR Rear LSD Conversion (non-viscous) with GTR Rear Axles & Hubs
What it needs to be a competitive drift car again or street rego'd (was rego'd up to a few months ago)
-has the motor etc in there already and clutch still on there however motor has an issue, my plan is to get a rb20 long motor and manual box and a bonnet and im away again. Or if i get more coin will put a 25 motor and box in.
If i get time i will finish the car and paint it, but have a few other cars in the way
Is sitting in my parents garage on the gold coast so would be after a keen buyer who will come with a tow truck or trailer and take it home, is a fair price
Will do cheaper with easy items removed
Offer Away, altho wont give it away, this car handles very well and is a very capable top end slider with a 25 etc
rob
0418 762 797
also have a hilux minitruck for 3k
Edited by jp_180sx
