hey guys and girl...
i am havin few problems wif rb20det...
first of i recently been haing proble wif it starting when hot... say i come off the highway get home... let in wind down and turn it off... then come back 5 mins later it just wond over and over and wont start sometimess if u pumpit it will start then die again... i dont no wat it could be i checked plugs, coil packs ,afm.. and the all seem to be fine (tried them on another car)...
anyone no what it could be...
second...
this might be causing my first problem... dont no but...
i am seeming to pushing out alot of oil in my catch can.. i mean alot i almost filled the thing in way day...
wat would cause this... i have benn told rb's are known for doing this.. but i didnt think it was that much oil...
any help would be awsome
thanks roger
https://www.sau.com.au/forums/topic/328716-problem-wif-my-rb20det/
hey guys and girls,
i am having a few problems with my rb20det.
first off i recently been haing problems with it starting when hot. say i come off the highway, get home, let in wind down and turn it off. when i come back 5 mins later it just cranks over and over and wont start, sometimes if you pump it, it will start then die again. i dont know what it could be, i checked the spark plugs, coil packs, and air flow meter. they all seem to be fine (tried them on another car to confirm).
anyone know what it could be?
second,
this might be causing my first problem though i am not sure,
i seem to be getting alot of oil in my catch can. i mean alot, i almost filled the thing in one day.
what would cause this? i have been told rb's are known for doing this, but i didnt think it was that much oil.
any help would be awesome
thanks roger
there i helped people read it.
yeah my spelling and typing isnt the best...i'll try to keep decent..
umm all i have done in mods is front mount and fuel pump..
i did do a search and it came up wif.. to check plugs / coild packs and afm for not starting...
and if my rings wear gone wouldnt throw lots of wite / blue smoke out the zorst.?
cheers roger
Edited by regor
a compression test wont be nearly as useful as a leak down test - get both done and then you will know, but when my old CA18 started filling up the catch can and FMIC pipes i knew the rings were gone
rb20 motor is cheap as chips anyway ~ 1k
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
