hey guys and girl...
i am havin few problems wif rb20det...
first of i recently been haing proble wif it starting when hot... say i come off the highway get home... let in wind down and turn it off... then come back 5 mins later it just wond over and over and wont start sometimess if u pumpit it will start then die again... i dont no wat it could be i checked plugs, coil packs ,afm.. and the all seem to be fine (tried them on another car)...
anyone no what it could be...
second...
this might be causing my first problem... dont no but...
i am seeming to pushing out alot of oil in my catch can.. i mean alot i almost filled the thing in way day...
wat would cause this... i have benn told rb's are known for doing this.. but i didnt think it was that much oil...
any help would be awsome
thanks roger
https://www.sau.com.au/forums/topic/328716-problem-wif-my-rb20det/
hey guys and girls,
i am having a few problems with my rb20det.
first off i recently been haing problems with it starting when hot. say i come off the highway, get home, let in wind down and turn it off. when i come back 5 mins later it just cranks over and over and wont start, sometimes if you pump it, it will start then die again. i dont know what it could be, i checked the spark plugs, coil packs, and air flow meter. they all seem to be fine (tried them on another car to confirm).
anyone know what it could be?
second,
this might be causing my first problem though i am not sure,
i seem to be getting alot of oil in my catch can. i mean alot, i almost filled the thing in one day.
what would cause this? i have been told rb's are known for doing this, but i didnt think it was that much oil.
any help would be awesome
thanks roger
there i helped people read it.
yeah my spelling and typing isnt the best...i'll try to keep decent..
umm all i have done in mods is front mount and fuel pump..
i did do a search and it came up wif.. to check plugs / coild packs and afm for not starting...
and if my rings wear gone wouldnt throw lots of wite / blue smoke out the zorst.?
cheers roger
Edited by regor
a compression test wont be nearly as useful as a leak down test - get both done and then you will know, but when my old CA18 started filling up the catch can and FMIC pipes i knew the rings were gone
rb20 motor is cheap as chips anyway ~ 1k
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
