Howdy, I have a series 1 R33 Skyline for wrecking here in Sydney. It's got a few mods listed below:
Rb25det head - approx 120,000ks, good condition, clean as! includes everything from the rocker covers down, no CAS though - $500 ono
5sp Manual gearbox. Good condition, no crunches or noises - $1300 inc tailshaft, shifter and crossmember, or a whole manual conversion kit for $1500 ono
Greddy intake plenum. great condition, includes throttle body adapter - $900 ono
Siemens 770cc injectors + aftermarket fuel rail, speedflow fittings, includes plugs & wiring - $700 ono
Garrett gt3540 / gt35r bolt on turbo kit.. $2100 ono
.70 front, .82 rear, great condition - looks brand new, no smoke or oil residue anywhere, minimal/negligible shaft play
Includes Highmount manifold, 3" dump/front pipe & o2 sensor, braided oil feed line, water lines & fittings, external wastegate w/ screamer, stainless intake pipe to AFM, hose clamps & reducers, everything in the pictures! Can ship it anywhere in Oz
post-35556-1279006742_thumb.jpg post-35556-1279006756_thumb.jpg post-35556-1279006784_thumb.jpg post-35556-1279006794_thumb.jpg
Sard fuel pressure regulator - $150
Z32 AFM + plug. I accidently put a small crack in the side of it :S Still fully working though - could be glued/taped or whatever - $150
Greddy Emanage ultimate ECU, with wiring loom to suit R33 - $800
Exedy HD sports tuff clutch, looks almost brand new - $200
Bosch 044 fuel pump in a R33 cradle, great condition - $150
3" Decat pipe to suit R32, R33, S13, S14, etc - $50
Superspark coilpacks to suit S1 R33 rb25 & rb26, R32 rb20/rb26 - $300
G4 racing coilover set, front & rear. Damper / height adjustable + great condition, no leaks. Suits R33 Gts-t - $650
Monza blue anodised catch can + lines - $80 ono
3" catback exhaust with rear cannon muffler, mid muffler is a bit dented - $250 - pickup only!
HKS turbo timer + Nissan harness - $60
Turbosmart boost Tee, Black - $50
Also have most of the stock parts left for sale:
Engine stuff:
S1 Rb25det engine loom - $200
R33 aircon compressor - $100
R33 power steering pump - $100
R33 alternator - $100
Engine Mounts - $80/pair
Fuse box lid - $20
Washer bottle - $20
Radiator overflow bottle - $20
S1 ABS unit - $100
BM44 ABS brake master cyl - $75
Standard RB flywheel, recently machined - $75
Standard sidemount cooler/ SMIC & piping - $80
Ignitor - $70
cam covers - $50
Harmonic balancer - $100
Brakes/driveline:
Front calipers - $275
Rear calipers - $150
Front rotors, used but good condition - $50/pair
Rear rotors, used but good condition - $50/pair
Castor rods with urethane bushes - $80
Front lower control arms - $70 ea
Front upper control arms - $50/pr
Front 5 stud hubs - $50 ea
Rear lower control arms - $50 ea
Rear 5 stud hubs - $150 pair
Handbrake drum assembly incl cables - $150 pair
Manaual (4.11) ABS diff - $250
Driveshafts $75 pair
Spare space saver wheel - $50
Inside:
Floormats, missing 1 rear mat - $offers
Drivers side window switch (s1) - $60
Drivers side window motor - $100
Passenger side window motor - $50
Front S1 door trims - $80
S1 non-airbag steering wheel, pretty worn - $offers
Centre console - $50
Front seats, few cig marks + wear on the drivers seat where you get in - $80/pair
Seatbelts (full set) - $80
Ignition barrel + key - $80
https://www.sau.com.au/forums/topic/328761-wrecking-modified-r33-gts-t-sydney/
  • Replies 86
LNah, yep I can post anything anywhere. If youre keen on the compressor send me a PM
RuthlessRick: Sorry mate it would cost something like $300AUD to send it there by airmail with insurance
please let me know if your willing to split the exhaust manifold
No worries, will do
Hi Mate after the Heater temperature mode actuator located on the driver side of the heater unit. Can uo PM me if you have it?
Cheers
Yup I should have it, PM sent
Diff, cluster, climate control sold
injectors & plenum on hold till sunday
hey mate chasing very top left passanger side grill/vent, the 5x5cm (or there abouts) one.
and what condition is the diff in?
Hey mate, the small vent in the dash pad? don't really want to separate it sorry mate
Diff is sold!
Ill take the handbrake assemlies if comes w/ drums n handle the lot??
yep comes with cables, drums and backing plate- this here:
hey keen on the injectors and rail can you send them to bris and how much let me know 0438298770
Heya, injectors are on hold till sunday, i'll let ya know if it falls through
Cheers
    • Aren't these run off of high voltage in OEM applications? Like 200+V. Or at least 48V in mild hybrids. At ~18,000 BTU ballpark nominal capacity the power draw is at what, 2.2 kW? ~185A is a pretty crazy amount of amps. At 200V it's only 11A. The 70A nominal kits with up to 100A peak draw I see for stuff like classic Porsches have pretty substantial compromises like shutting off at idle and not actually managing to keep the interior cool in hot conditions because they can only output like 6000 BTU. IMO if I had to pick what high amp draw component to retrofit to these cars I would start with the engine fan, not the AC compressor. You need an ~850-1000W brushless fan, something like this: I would love to see the data but I would bet that whatever you save by running the AC compressor in a more efficient regime with an electric motor you're probably losing to conversion losses anyways. It's not really like a clutch fan where you're losing power all the time even when it's nominally disengaged and it gets worse as it engages because the envelope tracking isn't that precise.
    • I am a volunteer marshal at the Grand Prix. As such, I get a "friend / family" ticket. It is a general admission ticket, valid for all 4 days. Anyone interested in my spare pass, please DM me. Ticket is "free, gratis and no expense".
    • agreed, the price vs gains it’s there.   unless you go china supercharger. Temu racing anyone?😂https://www.facebook.com/share/15nkfpsg7Z/?mibextid=wwXIfr that was one of the ones that popped up on my feed 😂
    • Bit of a long shot but if anyone has 4 of these laying around in new or near new condition. I will happily buy them off you.     https://skylinespares.com.au/product/stabilizer-door-glass-inner-new-8032404u03/?srsltid=AfmBOop6L5EgUFaHPHiVXoAhv5k8aJYwc77nGmoApp-hY03OiOsNVaOv Thanks
    • I'm wondering is the Toyota and Mazda "collaboration" could see that new Toyota ???G20 ??? turbo engine that they have been showing off recently into a future MX5, apparently it's good for 400hp out of the box That could easily, possibly, be much better than the last collaboration between Toyota and Subaru with the boxer engine in the twins
