  • Replies 86
Hey man, would you sell the wastegate and screamer? Also do you have the little relay module which attaches to the top of the abs pump? Pm me a mob num or address I'm happy to come down and look, with a wad of cash.
hi bloke ill grab the drivers side window switches and handel, can you find out cost of shipping to mackay? thanks just pm me and ill sort out payment with you.
044 fuel pump, rear hubs, spare wheel, turbo timer Sold
Hey mate, sorry i'm looking to keep it all together at the moment. PM sent
PM sent
hey mate, interested in the whole turbo kit. you have pm.
pm replied :)
Diff, cluster, climate control sold
injectors & plenum on hold till sunday
Hey mate, the small vent in the dash pad? don't really want to separate it sorry mate
Diff is sold!
yep comes with cables, drums and backing plate- this here:
Heya, injectors are on hold till sunday, i'll let ya know if it falls through
Cheers
have they sold or not
Greddy plenum, injectors/rail, sard FPR, stock SMIC/piping - SOLD
HEY INTERESTED IN THE 044 PUMP I LIVE IN SYDNEY CAN U CALL ME 0416367425 OR MSG IL CAL U BACK
Hey sorry mate the 044 is sold
best price on the catch can delivered to brisbane 4032??? OM ME BACK MATE
$90 delivered to 4032, PM me if you're keen
Yeah sorry mate, plenum, injectors/rail and the sard FPR are sold
5 Stud front hubs-PM sent
PM replied!
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
