  • Replies 329
Posted Images
No biggie for me mate, it was on the exact same dyno not even 3 weeks prior so it really didn't bother me. Much rathered giving my spot to Matty to see if he could fix his issues on a second run :D
thanks for that too luke
much kudos to martin and kier and the boys at willall. especially for the advice regarding my rather shit state of ignition timing, and the lend of a timing light (and roo's spare CAS too). at least i can confidently say that i know it wont blow up next weekend :D
Looks like i missed an awesome day! Totally spewing i had to go to the show instead.
That you did considering the show is crap :D
Not a problem bud. Like I said to you on the day; atleast you know what's wrong with it and what needs to be fixed. Just get on top of it before something else rears its ugly head. GTR's can get $$$
yeah, thats it. at least it'll be alright for this weekend, then i can take a breath and sort it all out. turbos, oil lines, cams (maybe LOL)
What would be cool is if we could get a big ass graph with everyones power curves overlaid
would really put things into perspective, not just be about peak power but to also show how responsive some cars are
not sure if it can be done but it'd be awesome if we could do that next dyno day :D
also some r32 gtrs were ran awd and some were ran rwd - bit of a discrepancy there for the sakes of comparison
those are the only two things that I think would improve the next dyno day - beer would probably improve it too
-D
Willall don't like Running 32 GTR's in AWD as it stuff around with your attessa
as for graph would possibly look like a mess a 5 yr old has drawn
depends how u overlaid it
obviously you wouldnt have a 100kw car on a 200kw chart nor a 200kw car on a 300kw chart
colour coded lines are done all the time. sure it could be done, even if one had to plot graph points into another piece of software
the first bunch of gtrs were ran in 4wd... didnt seem to have any visible problems? only ones that werent ran in awd was my own and panzers.. i for one was very keen on seeing how much power loss i'd get in 4wd mode as opposed to rwd only
-D
and RH9
you only see a difference of 5% with AWD
yeah the overlay could be done, not 100% sure what it achieves as there is 25 cars run with almost 20 different tuners
doesnt matter what the tuners are - the result on the same dyno is the benchmark - and thats why it would be interesting to see.
its all very well and good for me to go to my tuner and get a printout, but every dyno is different - if u neutralize that variable by having them all ran on the same dyno (pref all in rwd tho i know it cant be done) then you'd get a good idea of actual real world power and torque curves
not criticising the event in any way at all, just that would be the icing on the cake imho
-D
My car was about 16kw different from 4wd to rwd on GW's dyno.
how much were u doing in both awd and rwd? interesting a percentage value so i can compare it with other peoples results - can help when regarding how efficient the transfer case is on any given power level - as well as the comparison between the 33 and 34 attessa systems to the 32's admittedly slower reacting attessa
-D
Just a quick heads up - none of the R32 Based cars were run in AWD mode. The reason for this is that their ATTESSA control doesnt operate consistently on the dyno, any dyno, hence its not good for the life of the transfer case - and 32 transfer cases are - very - fragile. What you may have seen is some of the earlier run 32s set up on the rear bed, as we had the dyno set is RWD/AWD mode and the straps setup to run the cars this way (we let MattyTs GTR run the front wheels for a bit as we believed it had a fault and we could identify it that way for him). There should be no difference between running front bed/rear bed in terms of power. Notably one of the GTRs went 309rwkw on the rear bed in the morning, and at the end of the day when it (the engine) was a lot cooler it ran 316rwkw which is about right. We test the variance between the beds regularly :P
cool thx for clearing that up :D looks like the 32s all had pretty interesting results
I was sure that redbacks nur would be pulling more than he did which is why I thought i'd ask
-D
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
