If you are in no dire need of your four wheel drive system to work as sharply as it did from the factory then keep going with your existing transfer case. Like every other part of the car they wear out, and the more power, the faster :)
We have several rebuilt cases that we had done (new frictions and steels) that we swap out from time to time on the cars. The parts are available from Nissan :P
Nah, I'd rather refresh it to brand new standard as part of the general rebuild... As soon as I can get a price from ya, I'll check my calendar and see when I can get it done :laugh:
-D
EDIT- This is the link I was reading about xfer rebuilds and the corresponding prices for the parts http://www.skylinesaustralia.com/forums/R3...amp;pid=5227996
  • Replies 329
Posted Images
Ben, David has a PowerFC - in fact it is the R32GTR one out of the R that was written off in Targa Tasmania a few months ago (as his old one shat itself). And yes, it is tuned rich as FCUK atm while he fully runs in the motor. Mind you he is not out for HUGE power, as he has chosen response rather than massive numbers - he is running a pair of HKS 2530s - my favourite turbo :(
Andrew, overly rich mixtures can offer cooling & lubricating advantages but too much fuel can have adverse effects at the same time.
Excess fuel wash = goodbye critical bore cross hatching & hello glaze city..............not to mention that ceramic cats don't take too warmly to bucket loads of unburnt fuel. :)
Yeah I know Pete - I am not the tuner (Martin is) and I am not the workshop who did it (Manta is - and Steve has built a cubic SHIT-TON of wicked cars). I am sure they know what they are doing.
That said, David's power figure was not bad for low boost and everything taking it nice and easy on a full run-in tune. About right with little 2530s I would have thought - they only start getting up into their stride when they hit 18-20psi - I believe his tune was done at 12psi for now.
For those that were worried about what they saw coming out their exhausts on the day (black trails etc) there were very few if any cars that we could determine on there as being overly rich. A couple had a little too much fuel in the midrange, but nothing was actually drowning in its own fuel as you normally see from time to time at dyno comps. The black soot blasting out of the exhaust systems is normally the residue of cruising around being hammered out of the pipes by some high rpm airflow and heat. Black smoke on the dyno is normally a sign of a very gentle driver :)
cheers Martin for showing me your nifty calculation between the Dyno Dynamics and Mainline Dyno's
my previous runs on Dyno Dynamics Dyno were exactly along the same lines as in the graphs with the calculation.
Thats not actually a Mainline thing....and they dont really like me doing it...BUT
Having had a DD then swapped over to Mainline some of my customers wanted to see where their kw went (when in fact it went nowhere!) so I used the custom Math Channel function on the Mainline to write an 'Estimated Dyno Dynamics' correction factor, which as you can see works pretty well :action-smiley-069:
We also have a Dynojet HP Channel thing as the Americans really like to see their power readouts in 'Dynojet HP' and dont like kw :(
Good news is your car would make 500rwhp on a Dynojet no worries!
so martin what is the difference in percentage between mainline and dyno dynamics?
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
