Hey guys, i've currently got one of them Cyberstork white face dial covers. The only problem is that the R32 GTS-T gauge needle is still white, which would make it hard to see with a white background. Anybody have experience with this or know how to solve the problem? Would the needles even be interchangeable with the R33 or any other cars? Help is much appreciated. Thanks.
Here's a pic of what mine basically looks like stock.
http://i9.photobucket.com/albums/a79/d13so...3m/IMG00112.jpg
https://www.sau.com.au/forums/topic/328821-red-needle-on-r32-gts-t/
r32 gtr ones are red. just swap them
be careful if u choose to take to needles off .... i f**ked mine up when i was swapping over to white dials and spent afew hours with a gps trying to get the speedo accurate again -.-''
Edited by aussietroy
LOL, better not touch it then, doesn't look too bad...
On the other hand, i did touch my fuel gauge...does it automatically adjust or do i have to disassemble the whole dash again and touch it?
Swapped to Cyberstork white faced gauges with grey background and i must say it looks horrible (at night). The red LEDs that i bought off 666DAN barely shone through and is patchy, some characters don't line up (despite an hour or 2 of lining it up), and is less visible at night than stock. Stuck between changine the faces to stock or just leaving it :)
(And no i'm not gonna fork out $800 for the Nismo ones...)
Here's a few pics of the result, day time it looks very nice.
Edited by TyresBro
Ahhh they're overlays, so yeah if the numerals aren't bang-on, the light isn't going to come through. Have you got anyway of removing the factory plastics and just leaving the cyberstork ones in place? I would have thought Cyberstork would have been a failry good item, maybe not :)
For painting the needles, go to autobarn and get red lens repair spray in a can, it's clear and bright red, woks a treat.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
