hey all, ive owned this car for about 3 weeks, and it has a set of volk racing wheels, unsure on the exact brand, anyway, i cant get a socket or wheel brace to the nuts, the wheel nut holes are to small, where can i get a small socket to fit the nuts?
ta
https://www.sau.com.au/forums/topic/328853-cant-get-socket-on-wheel-nuts/
maybe buy some internal hex wheel nuts?
thats what i had to do with my '32. the nuts are M12x1.25.
i paid $40 for 20 of them and they came with a hex bit as well.
other than that Stahlwille make some very thin walled sockets but they are massivley expensive. try about $750 for a basic socket set.
you may need to get a good quality socket as the cheaper ones are too thick to go in. then as said above, get some of the allen key head nuts.
or you can do what old mate in the honda did and take to the wheels with a saw............ LOL
as for getting the old ones out, best bet would be to drive to a hardware shop, or a decent tool shop and explain to them your problem and see if they will let you try some sockets to see if they fit. generally your better sockets such as stanely, kingchrome, snap-on etc will make skinnier sockets because they are made from stronger steel so don't need to be super thick to make up for being weak.
some tool shops have those annodised slimline sets in 4 colours that have the plastic covers on them to stop the socket from damaging the wheels. these are normally long and skinny for this purpose.
DO NOT USE INTERNAL HEX WHEEL NUTS!!! Had these on a rally car I bought and after heating cooling and a few wheel changes (fair enough rally car gets wheels on and off a lot more than a road car..) the pressure out on the inside of the nuts cracks them. If you simply think about the pressure is being applied as you tighten and loosen you will soon see how easy this can happen.... It may be poor quality, it may be a lot of work and all the hot cold, but I will still never use them again
you more than likely have 13/16th or 21mm nut's, best bet is uselly to use a spark plug socket, these are thin in the wall
and will get you out of trouble.
Nissan use 21mm wheel nut's, head down to your local tyre shop and buy some 19mm nut's and you should be right
and i aggree DO NOT use those stupid inner hex nut's, the amount of these that i've had to remove is huge..
you have to drill the head of the stud, and it's a massive pain in the arse, and we charge $65 per nut removelly
The Enkei rims I got came with a thinner extension as most sockets cannot get to the nuts due to the wheel design.
I'm sure you can buy them somewhere, or you can take any of the above tips.
LMAO!!! that link is hilarious. i like how the honda boys are blaming it on VW........who cuts a wheel. honestly. and then tries to justify doing it? hilarious read. my life if now better having seen that.
sry was off topic (sorta), all ideas above are good :P
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
