hey all, ive owned this car for about 3 weeks, and it has a set of volk racing wheels, unsure on the exact brand, anyway, i cant get a socket or wheel brace to the nuts, the wheel nut holes are to small, where can i get a small socket to fit the nuts?
ta
https://www.sau.com.au/forums/topic/328853-cant-get-socket-on-wheel-nuts/
maybe buy some internal hex wheel nuts?
thats what i had to do with my '32. the nuts are M12x1.25.
i paid $40 for 20 of them and they came with a hex bit as well.
other than that Stahlwille make some very thin walled sockets but they are massivley expensive. try about $750 for a basic socket set.
you may need to get a good quality socket as the cheaper ones are too thick to go in. then as said above, get some of the allen key head nuts.
or you can do what old mate in the honda did and take to the wheels with a saw............ LOL
as for getting the old ones out, best bet would be to drive to a hardware shop, or a decent tool shop and explain to them your problem and see if they will let you try some sockets to see if they fit. generally your better sockets such as stanely, kingchrome, snap-on etc will make skinnier sockets because they are made from stronger steel so don't need to be super thick to make up for being weak.
some tool shops have those annodised slimline sets in 4 colours that have the plastic covers on them to stop the socket from damaging the wheels. these are normally long and skinny for this purpose.
DO NOT USE INTERNAL HEX WHEEL NUTS!!! Had these on a rally car I bought and after heating cooling and a few wheel changes (fair enough rally car gets wheels on and off a lot more than a road car..) the pressure out on the inside of the nuts cracks them. If you simply think about the pressure is being applied as you tighten and loosen you will soon see how easy this can happen.... It may be poor quality, it may be a lot of work and all the hot cold, but I will still never use them again
you more than likely have 13/16th or 21mm nut's, best bet is uselly to use a spark plug socket, these are thin in the wall
and will get you out of trouble.
Nissan use 21mm wheel nut's, head down to your local tyre shop and buy some 19mm nut's and you should be right
and i aggree DO NOT use those stupid inner hex nut's, the amount of these that i've had to remove is huge..
you have to drill the head of the stud, and it's a massive pain in the arse, and we charge $65 per nut removelly
The Enkei rims I got came with a thinner extension as most sockets cannot get to the nuts due to the wheel design.
I'm sure you can buy them somewhere, or you can take any of the above tips.
LMAO!!! that link is hilarious. i like how the honda boys are blaming it on VW........who cuts a wheel. honestly. and then tries to justify doing it? hilarious read. my life if now better having seen that.
sry was off topic (sorta), all ideas above are good :P
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
