Hi all. as titles says i need a gtr airbox with snorkel. if you have one let me know. thank you
BTW i have a pair of Blitz Twin pod filter with metal adapters that i can swap with you if your into pods. cash your way.
Edited by Mingy
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
