Hi guys,
I just purchased a HKS intercooler at a good price. But the downside was it was very dirty.
I want to clean outside and in but not too sure about what to use.
Would such degreasers such as engine degreaser or CLR work?
What do you guys recommened and what method is best to use?
Cheers
https://www.sau.com.au/forums/topic/328875-cleaning-intercooler/
I cleaned out my standard intercooler with a whole lot of degreaser from supercheap auto, load the whole can inside the intercooler - swish it around, tip it upside down etc etc, hose it down and repeat... supercheap had the degreasers on special so you can repeat it as many times as you deam necessary until all the crud is out.
cheers
i will probably do the one most people are saying by using the petrol inside and using tape to hold it in
and then use the degreaser on the outside to try and clean it up.
I will let you guys know how it turns out tomorrow
cheers for the help
50 / 50 Metho and Kero mixed up, with some good quality duct tape on one of the end tanks. Swish it around for a good 5 minutes, then pour out and repeat till the stuff your pouring out is close to the same colour as what is going in.
To clean up the outside use the Bit Sus technique. If its not to bad perhaps start with 600 grit wet and dry :-)
Have fun. haha
