Chasing an alternative to the small lip spoiler that still allows me to do away with the factory one. I can have one custom made but it will cost more than $1000 and I can't bring myself to spend that sort of cash on a purely aesthetic mod.
Please feel free to point me in the direction of other companies that make such an item.
Cheers
Edited by PhilKenSebben
https://www.sau.com.au/forums/topic/328920-wtb-r33-flatflush-boot-lid/
dude i got one from do luck cost me a grand + fitting etc etc...do your self a favour an go the east bear carbon one...the weight of the do luck when fitted just adds to the normal boot weight as its just a boot cover and requires a panel shop to make it flush and look proper...east bear will bolt up lovely and fit perfectly give powerplay imports a call or import via jap website...but expect to pay around the 800$ mark unless you find a cheap one on yahoo auctions via import monster
The small lip spoiler you pointed out is what I'll settle for if I can't source what I'm really after before respray time, but here's hoping.
Thizzle is right, I'm after the East Bear specifically because I had read on a UK forum that the Do-Luck version was a sort of boot addition that would require time fitting, etc.
However, given how difficult it seems to be to get my paws on either, at the right price I'd settle for either, and a custom is job is not completely out of the question yet. I'm a patient person who can wait for the right price, but time is running out as I'd like it to get it done with the rest of the body.
I posted a WTB topic on R33 smoked side indicators probably a year ago and still haven't got my hands on some. May have to bite the bullet and buy them new for $100.
I'm stunned that more parted out wreck threads don't sell them.
And every now and then I stumble across old threads like, say, THIZZLE'S, where he sells the parts I want and then PRACTICALLY GIVES AWAY AN ENTIRE BLOODY SHELL FOR PEANUTS! And all because I never saw it when it was relevant. Balls............
  • 3 weeks later...
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
