Just adjust your headlights properly and they won't blind other drivers. I have HID's without projectors, used to blind everyone before I adjusted them, now they are fine.
Not worth paying hundreds of $$$ for.
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5347056
This is why I want a proper HID fit with projectors... notice how smooth and focus the throw of the light is with projector vs the one without.
The one without, all the light is scattered.
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5347066
Again, not worth hundreds of dollars. My HID's are not scattered. There are some slight hotspots close to the car where the light creeps out under the headlight. These photo's are really old and I wasn't really focusing on the HID's, but you can sort of see what they look like.
I would install the HID's with the stock reflectors, then if you don't like them think about paying for some projectors. If you've ever seen R34 xenon headlights, they don't actually have projectors but the spread is still good. Personally I don't think you need projectors for HID's, but having said that I do think the projectors themselves just look classy. Nothing to do with how they throw the light, I just like the look of projector headlights, looks more modern and refined. So I can understand wanting them, my argument is just based on the fact that you don't actually NEED them to have HID's.
Edited by Hanaldo
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5347674
" Personally I don't think you need projectors for HID's, but having said that I do think the projectors themselves just look classy. Nothing to do with how they throw the light"
Are you kidding me??
Are you that blind?, did you not see the youtube comparison - hid projector vs stock reflectors?
Perhaps you are lucky with your car with its standard reflector working well with hid, but I would say in the majority of cases, HId kit definitely
need projectors to bring the absolute best out of them.
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5348035
Why the aggression mate? I'm offering advice, no need to be offensive.
Did you ever think that maybe that bike just has crappy reflectors, as lots of them do? I've seen plenty of different cars with HID's and stock reflectors that look great, it's not hard to get rid of hot spots. Have you tried installing HID's in your car with the stock reflectors? If not then do it, you won't lose anything and you will be able to see how they look with your cars stock reflectors. If there are hot spots, try eliminating them, it's not hard and in most cases you can get rid of all of them. If you still don't like it, by all means go and spend the money to get projectors fitted.
But whatever, it's your money and I'm blind.
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5348120
I am not trying to be aggressive, just flabbergasted by your comments.
Personally for me is quite clear cut whether projectors are needed in a HID setup, each to their own I guess.
I don't want to get into a debate with you on the finer points of whether projectors are needed in HID installation or not, so back to the original topic.
Can someone recommend me a good workshop that can do the proper fittings I have described?
I found a good kit on the net, just waiting to see if someone in Perth can do a proper HID retrofit and I am good to go to order the kit.
"http://www.hidplanet.com/forums/index.php" - good info on HID if anyone is interested
Edited by neon_tetra
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5348290
easiest way would be to fit S3 R33 GTR lights, thats if you have a R33 lol. even then you have a to modify them a bit to make them fit...personally i wouldnt bother... ive got hid's on my R33 and no problems...as said b4 adjust them properly
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5349467
Hi
Anyone know any good autoelectrician in Perth that can do a proper HID retrofit?
that includes modify lights to fit proper hid projectors so I don't blind other drivers.
Attach is an example of a proper retrofit and just not plug and play.
after having a quick look through that first link u posted - the civic, no autosparky shop is gonna be interested in doing that, its more of a DIY job, u mayyyyy find someone whos willing to do a cashy but it looks like theres a shitload of hours involved (as i said i had a quick look through it) so its gonna be very expensive to pay someone else to do it for u.
i didnt see the comparison vid of the projector vs non projector hids, yes there probably is a big difference between the 2 but for everyday driving normal hids are fine. ive had mine for about a year i drive my car everyday and nearly every night, i havnt even aimed my headlights since ive had the car just swapped the old halogens out for my 6000k bosch hids and ive had no problems whatsoever, i havnt been highbeamd or flashed once so they mustn't be blinding people, not one cop has pulled me over for them - ive been pulled over a few times at night the cop has checked over the whole car and not even mentioned the hids, and i havnt had any problems with visibility there wayyyy better then the factory light ive only ever needed highbeam on country roads (so i see animals and crap like that in the distance)
https://www.sau.com.au/forums/topic/328959-hid-retrofit/#findComment-5352482
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
