Hi Guys,
I need to run new fuel and brake lines on the track car (and clutch too, stupid transaxle), and I was wanting to put them in the cabin to keep them protected.
Is this safe? I had a look in the cams manual and all I could find was for rally cars (Shedule R, Section 13) that says it is OK.
I plan to run bulkhead fittings at the front and rear of the cabin and solid lines between them with no joins, and no flexi hose, with the exception of the rear brake line which will need to connect into to a hydro handbrake and bias adjuster so there will have to be joins there.
What tubing is best to use? I have heard good old steel 'bundy' tube is the best option as ally and stainless are more brittle and will crack?
Cheers,
Martin
Rules on fuel and oil runs should be in the category regs not the schedules. Other than Nascar, can't remember anything prohibiting brake/clutch fluid line in cabin.....and the past and present car would be in the doo-doo if that was the case.
In the 2nd category they do have some specification on lines. The 3rd category one I'm familiar with, permits fuel in cabin with only bulkhead fittings and no other joins, no spec on whether flexible or hardline either.
You'd be hard pressed to look past bundy for brakes, fwiw, annealed stainless is used in some aircraft fuel systems, vibration support being the important aspect.
If there are no joins in the cabin, then there should be no issues from scrutineering. The reason that Aluminium and SS are advised against is that they become work hardened from the constant vibration present in the car, this leads to fatigue cracking and failure of the pipework.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
