Hey everyone,
i searched high and low for this interior (total 6 wrecks) and have run into problems with my motor and need money to fix it first
contact - 0420 855 181, [email protected] or PM
1. dash (with all vents in perfect condition, including dimister vents in perfect condition, no bubbles or peeling covering)
2. cluster surround (this is what lets this combo down, has holes drilled for ebc, missing switches in pic, but will be included)
3. steering colum trims (with keybarrel surround)
4. fuse panel trim (inc hks turbo timer)
5. center console (includes ac controller, 3x gauge holder, and din pocket)
6. radio surround (perfect condition)
7. glovebox (with trims)
8. all ashtrays, cig lighter etc
8. door trims, perfect condition, minor mark on underside (cannot be seen)
9. cluster (has got autogauge gauges in factory positon "water temp, oil temp and oil pressure")
price: want to sell complete for $600 ono if i have no interest i will post up seperate prices.
pictures: (can be clicked to enlarge)
Edited by 32_Dave
https://www.sau.com.au/forums/topic/328986-r32-interior-parts/
split prices will be...
1. Dash - $150
2. Cluster surround - Free with dash or Seperate $20
3. Steering Column Trim w. Key Barrel Surround $30
4. Fuse Panel Trim w. HKS turbo timer $50
5. Center Console w. (w. Ac controler, 3gauge holder and Din pocket) $80
6. Radio Surround - $60
7. Glove Box w. Ashtray - $40
8. Door Trims - $100
9. Cluster - $250
BUMP
1. Dash - sold
2. Cluster surround -$15
3. Steering Column Trim w. Key Barrel Surround $15
4. Fuse Panel Trim w. HKS turbo timer $35
5. Center Console w. (w. Ac controler, 3gauge holder and Din pocket) $60
6. Radio Surround sold
7. Glove Box w. Ashtray - $25
8. Door Trims - sold
9. Cluster - $200 (gauges inserted are around 80-100bux a pop)
1. Dash - sold
2. Cluster surround - $15
3. Steering Column Trim w. Key Barrel Surround - sold
7. Glove Box w. Ashtray - sold
1. Dash - sold
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
