Few Questions Regarding Upcoming Mods
I have the hks 2835 pro s turbo on my car. Happy enough with the power. Most I've had it at is 267kw @ 15psi. Didnt want to strain the turbo too much after blowing my last one. Happy with the power and the lag.
Also as far as im aware hks have now brought out the 2835 kai turbo, which I believe is an improvement on the pro s. If you really want the 3076r I'd talk to Mick as well, as he is running it on his 25.
edit: one of the reasons I went with the hks turbo, was apart from the heatshield it pretty much looks factory, and is a direct bolt on.
  • Replies 100
Posted Images
Also why are you after the v66 plugin ecu? Any additional benefits over the v44 plugin? I'd make sure you talked to Glen at ESP about the VIPEC as well.
Given Kris' claimed results on an internal, and the mention of police attention (I haven't been looked at twice by cops since I bought the car....first 5 or so months it had 5% tint all round so go figure) I'm leaning towards internal a little more at this stage, depending on just how much more external will end up being.
v66 still runs wasted spark I believe....unless I missed the part where they changed it. It's just the v44 but plug-in
EDIT: you said injector not ignition, my bad.
Edited by Trozzle
If your going the vipec, make sure you figure out what additional stuff you want it to control before getting it installed, but you probably already have it covered.
By additional stuff, what do you mean?? I'm sure I have most of it covered, if I knew what you meant exactly....like boost control, launch control, birth control?
having made a boo-boo and ordered an EXTERNAL pump, not INTERNAL like I thought (bloody hell 040 and 044 look the same at a glance hey...) I'm now going to be receiving something I can't necessarily use all too easily. Can anyone point me in the direction of info regarding what's needed to use an external pump in place of an internal one? Might as well go with my f**kup now and use it, if it can be without too much trouble...
This is what you want...Bargain
Garrett gt3540 / gt35r bolt on turbo kit.. $2100 ono
.70 front, .82 rear, great condition - looks brand new, no smoke or oil residue anywhere, minimal/negligible shaft play
Includes Highmount manifold, 3" dump/front pipe & o2 sensor, braided oil feed line, water lines & fittings, external wastegate w/ screamer, stainless intake pipe to AFM, hose clamps & reducers, everything in the pictures! Can ship it anywhere in Oz
http://www.skylinesaustralia.com/forums/Wr...ts-t328761.html
Hey krayzie he could get that but the lag is just too bad on a 3540, i was considering upgrading my turbo to that but everyone kept saying its not that good for street due to the lag. There is a reason why many people say that the 3076R is the best turbo for the rb25 for street.
Heres my dyno sheet for my claimed power.
Im sure you will be able to get it to fit internally, just might need to customize the bracket to where its mounted too.
044 on factory rail
sweet, yeah I read into it quickly now that I'm home, and it can be mounted internally....just with modification to the bracket. That's ok with me lol.
And thanks for the dyno sheet man, makes me happy to see that work so well with internal gate etc
I'm not even after top end too much anyway, so a small drop up the top doesn't phase me. I realise that since I'm not after top end, that means I'm after response and pull...which is better with an external gate anyway :( either way, can't wait Kris I know I'll love it :D once I sort out how you have to mod this bracket for the 044 >.>
Yea I'm running a blitz sbc spec r. The spec s was shit because it would spike and then drop to the right level. The spec r doesn't spike and only loses 1 psi which I'm real happy with
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
