Few Questions Regarding Upcoming Mods
  • Replies 100
Posted Images
TTT...
Last question I have for you TiTAN, then everything is clear and I'm set - what exactly do you mean by "big can actuator"? The more I think about it, the more my brain hurts. Do you mean that the actuator itself is physically large, or just a higher pressure spring, say 16psi?
I'll have to read it thoroughly when I get home TiTAN...but I'm still not sure if I'll be able to describe/ask for what I want specifically, and might end up f**king around either CRD or GCG...or being f**ked around myself lol.
Just gotta work out what I need to ask for, and if they ask what I mean, be able to describe it.
What benefits does the HKS housing have? bolt-on? Keeping in mind I'll be going I/W to save having to get a new dump/police attention
Ifr its what i think it means, you can get in between size exhaust housing as per 3037 ie .68, but I didn't read the whole thread so I could be wrong and you'd probably be able to use their split dump setup back to the cat, so no custom work required. Bolt on stuff and easy as.........would be much cheaper in the long run.
Yeah doesn't say internal gate....though as per above above post TiTAN, if they were to ask wtf I mean by "big can actuator", what would I say? "err yeah dude...it's big. Like fat. BBW.....ask Boz, he'll know!"
No worries, I'll just tell them and hope for the best :down: Should be soon....as soon as I get a return email from ESP telling me how much the ECU will be, rough labour costs, whatever else I'll need and tuning, should be sweet!
I'll be getting a set of splitfires too, but will a FPR be required? I've read mixed opinions on when a FPR is required, but I've been told I will....so just thought I'd ask.
no fpr, use the stocker.
MTQ are a garrett distributor and had no trouble supplying me a gt3076 with the garrett housing, they also machined the gate to make it a bit larger to make sure it didnt creep.
i bought nismo 555s and went with the IW option on the stocker manifold. now going external gate and probably bigger injectors, if i had my time again i'd go external from the start. just something to think about
Thats a good point, if your not worried about the turbo looking different to factory then may as well do it properly with an external gate. And definitely go the larger nismo injectors as they similar price.
by "right sized" you mean not excessively large? Or not small?
The only reason I really don't want to go external gate, is because I'm too inexperienced/noob/ignorant to sort out everything I'll need for it, and then source it myself. If I could tell the workshop what I have, what I want, and have them source it for me without any surcharge (except postage of course) then I'd be all for it...
And it's a street car for quite some time it may appear...a defect like that will f**k me royally
right sized meaning not too small. the nismos are a quality injector and wont have any trouble providing a decent mix at idle with 740s. you'd be mad to buy 555s when 740s are similar/same price. you allways want more power in the future
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
