Is it common practise to put different fitment wheels on 34 GTR's?
I have 9" all round but am considering new wheels.
Some I have seen are 8.5 front and 9.5 rear.
What is preferred and what offset.
18 x what is best fit and what offset ....front and rear
19 x what is best fit and what offset ...front and rear
https://www.sau.com.au/forums/topic/328997-34-gtr-staggered-wheel-fitment/
No! Same rolling diameter will be ok with the 4wd, but i think you will find some pretty heated discussions in here about retaining the same width for all wheels.
The jist of it is, none of the top gtr garages ever use staggered wheel sizes, diameter or width.
going different widths and then compensating with typre profile to try and get the same rolling diameter will probably still result in a slight difference in rolling diameter and probably isn't the best for the atessa system.
if i had an r34 gtr vs2 and money which u clearly have both of i would get 19x10.5 +12 or +15
i believe my man eugen will be able to help u out in this
http://www.skylinesaustralia.com/forums/5-...17-t327689.html
I stupidly tried this on a gtr once and the atessa system went nuts. Even when you are cruising along slowly, the torque would suddenly be ramped up to the front wheels, and you could see it on the mfd. It felt like the car was tramlining and you'd be fighting the steering on a perfectly straight road.
So been there, done that and never again.
And 10.5" wide +12 to +15 offset sits ideally on an r34 GT-R with about -0.5 deg camber all round. I've pulled to -3.5 degrees on the front and the rims look really sunken in. But with very minimal camber, there's no need to roll the guards and it wont stick out like dogs balls.
Yeah I have 19x10.5 +15 on mine and really need to reduce the camber to make them just "right".
I have about 3 degrees rear and they look a little sunken.
The 34 GTR has a wider track in the rear from factory, which is contrary to most other cars, incl 32/33 GTRs, and I personally wouldn't want to make the rear track any wider than it is in relation to the front, to do so could end up with quite an evil handler that would be fairly willing to swap ends once sideways.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
    • Not great at getting the camera out fast enough for cars driving. Even in traffic. S15 is in front of the kei truck.
