Guys, just noticed something with my car last night that hasnt happened before... any help would be great on where to take it or what to do.
When rolling there is a thud thud thud noise coming from what feels like the rear end.. feels like a tyre flat spot but i dont think its that cause it just started doing it last night and this morning.. its hard to pin point where its coming from with the exhaust. But i can feel it when rolling. Could it be suspension? diff?
Anyone had anything else similar, i hate when stuff goes wrong with your car, just gets you down :D
https://www.sau.com.au/forums/topic/3290-what-the-whered-that-noise-come-from/
yeah my mate has one of these mechanical diffs, and i know that noise quite well from driving it and sitting in it lots of times :mad: but its not that noise
its only when rolling straight, even accelerating :D
more noticeable when going slower though ;)
only when rollin straight? damn
jack the back of your car up and spin the tyres around to check there isent a piece of metal or sumthing stuck in 1 of your tyres!
So when i find a flat spot if there is one,  how can it be fixed? new tyre?  or can u balance it out?
if its bad its time for new tyres! :eek:
i locked my front up in my old car so bad that it warped the two front tyres so bad that at over 100 the car would bounce and the steering wheel rattle really bad!:
i locked the brakes the night before actually to avoid hitting a wabbit.. didnt think i had abs.. :D
where should i take it to get checked?
Well that would probably explain it....
You can get the tyres scrubbed but probably not worth it.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
