So, I've got an R32 GTR and it's playing up a little in the colder weather. I thought it was tune related as there was a cold start problem, but Trent has given it more fuel and that problem has gone now. Essentailly the residual problem is now whilst the engine is cold and under light throttle it seems to miss or hestitate a little.....It might be 4th gear 60km/h even throttle. Always sorts its self out once warmed up. No problems under power.
Now it has new plugs, new coilpacks, -7s, Nistune and as Trent had it hooked up to the computer only late last week I'll assume all is well with the tune side of things. The engine is healthy as a recent compression test showed 165 across all cylinders.
Any thoughts as to what may be causing this?
Thanks.
https://www.sau.com.au/forums/topic/329009-winter-blues/
could be the ECU pulling fuel out in closed loop and there is a cell thats not quite inline with the others and its a little lean, mine was doing this before, leans out going through/sitting on a particular cell and the ecu isnt fast enough to add fuel back in on closed loop and it splutters a bit as though its missing. once warm and out of warm up enrichment the problem went away.
does it always happen at the same revs with similar load?
https://www.sau.com.au/forums/topic/329009-winter-blues/#findComment-5347848
It's not that precise in terms of how it happens. Since the cold start issue has been resolved it starts nicely / normally and idles fine. Its after you've pulled away and given it a couple of gears and even out to a cruise that it starts. Yesterday was the worst it's been. I was driving home from work and it was about 10 degrees ambient. I have a short drive from my car spot to a set of lights and at the lights it nearly stalled. Idle was unhappy. Got going and it did it's stuttering thing until the temp gauge started to register. All was good from there.
So you're thinking it's tune related and not mechanical by the sounds of things.
https://www.sau.com.au/forums/topic/329009-winter-blues/#findComment-5347919
Could that be why my heater doesn't run full hot? I think you posted in my thread about that too.....
Different issue, the coolant temp switch is responsible for reporting the coolant temp to the ECU, if faulty it might be reporting the engine is fully warmed up when it isn't
https://www.sau.com.au/forums/topic/329009-winter-blues/#findComment-5349381
^ yeah it will be in the cold start tune. o2 feedback is only used when at running temp
mine was tuned at UniGroup by Yavuz and he confirmed car is left on dyno overnight so he can tune for cold start the next morning, anyways, he will look at it for me soon and will report back what the issue was
https://www.sau.com.au/forums/topic/329009-winter-blues/#findComment-5349662
Well, mine was left overnight too. Twas 4 degrees and it was looked at stone cold, first thing in the morn.
https://www.sau.com.au/forums/topic/329009-winter-blues/#findComment-5349767
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
