hey guys,
My mate was at a local wrecker recently and claims that he saw a C110 coupe shell. There are no badges, but apparently it is known its a Nissan, and he "thinks" its a skyline. I don't know much about older skylines, so we wiki'd some pics and he says it looks most like C110. What are the chances of this being correct? and if it is, would this make a decent project for a track hack, or not.
Thanks guys, and imput is appreciated :(
https://www.sau.com.au/forums/topic/329076-c110-shell/
hey guys,
Thanks guys, and imput is appreciated :woot:
post up some pictures if you can? it can be made into a great track car or what ever just google them and you will see what loots have people have done with them
https://www.sau.com.au/forums/topic/329076-c110-shell/#findComment-5351961
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
