hey guys,
My mate was at a local wrecker recently and claims that he saw a C110 coupe shell. There are no badges, but apparently it is known its a Nissan, and he "thinks" its a skyline. I don't know much about older skylines, so we wiki'd some pics and he says it looks most like C110. What are the chances of this being correct? and if it is, would this make a decent project for a track hack, or not.
Thanks guys, and imput is appreciated :(
https://www.sau.com.au/forums/topic/329076-c110-shell/
hey guys,
Thanks guys, and imput is appreciated :woot:
post up some pictures if you can? it can be made into a great track car or what ever just google them and you will see what loots have people have done with them
https://www.sau.com.au/forums/topic/329076-c110-shell/#findComment-5351961
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
    • I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
    • Which grit sand paper did you use on the pulley btw? Thought I'd ask so I don't scratch it up too much
