howdy all, new to the forum and new stagea owner just bought a 99 series two stagea not to much done to it pretty stock but nice and clean. all thats been done is a 3 inch exaust and a blitz boost controller. few things i gotta do kinda straight away i need to get new rotors and pads and the shocks are pretty dead to. gonna try and find some coilovers maybe second hand not sure or just get front and rear shocks for now and get it tuned and serviced properly.
https://www.sau.com.au/forums/topic/329078-new-south-oz-stagea-owner/
hey mate..
Im also new to the forum and im in the process of buying my stagea 99 series two. Just finding it hard to get insurance for it in order to drive it home from Melbourne. How did you go about getting yours insured?
hey mate..
it wasnt acually that hard hey. that youi didnt let me insure it cause its an import or some crap so i just stayed with just car insurance swapped it over from my vy wagon i sold payed a 60 buck difference and that was it. the cars insured for seventeen an a half and i payed eleven cash for it. that was fully comp for 850buks and im only 24. some places just dont like imports not sure if other people have had any problems but yeh thats all i did just car are good. shannons would i rekon but im not sure wat the price would be. hope that helped at all
welcome mate, good to see some more stageas around. any pics?
sorry man just one more thing i rekon you live at the end of my street hey in ocean acres estate. i had a white vy wagon. ive been looking for a stagea for ages and was just waiting for the price of em to come down a bit. just bought one about 3 weeks ago its red hey im sure u will c it kinda cant miss it. pretty bright. i rekon you might no my wifes couzin to his name is greg and he works at the new holden joint at victor im pretty sure hes a mechanic
Yeah i have done some research now and stags are pritty good to insure which is good news for us :woot: Got a quote with Just Car around the 1200 price and im only 20 so im happy with that :woot: have fun in ur stag :woot:
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
